Scotty's 13bpp '71
Sleepys-14
Re: Scotty's 13bpp '71
Postby Sleepys-14 » 31 Jan 2016 10:45
Yeah, ill be at autobahn. You can purchase General Admission tickets to get into the events. I believe they go on sale pretty soon. But yeah, the Gingerman event, there are thousands of spectators, so its not a small event. The autobahn event is just a time attack event, so there is no festival along with it. Let me know if you can make it.
Track Junky
Postby Track Junky » 16 Feb 2016 17:53
Got this custom length Rack coming from Coleman in about a weeks time! Stoked that in a few weeks time this piles gonna be a roller!
Scott.
Track Junky
Postby Track Junky » 24 Feb 2016 16:28
So I got my rack in today, looks just like the one in the pic above but this one is mine ha! This is the start to the zero bump steer chase!
Scott.
Track Junky
Postby Track Junky » 06 Mar 2016 05:44
This is the start of the rack and pinion mount, I did not get a pic of the finished piece but im quite sure this is the oddest part I ever made lol. So it gets drilled, sleeved and welded for the mounting bolts.
And here it is mounted to the rack, really happy with how this came out,
Lower outer control arm ball joint bracket mounts
Same bracket getting the bent tubes to make control arms.
Misc weld shots.
Scott.
Postby Byron510 » 06 Mar 2016 06:28
Damn nice work as usual.
I drool every time I see your jig table....
My father recently mounted a half rack to his '32 Ford project. It's running a dropped front axle, so the rack only controls one spindle and the drag link connects the two spindles on the axle. It look interesting to say the least, just not used to looking at strait axles.
I look forward to your control arm solution up front, keep the updates coming.
Track Junky
Postby Track Junky » 06 Mar 2016 07:07
Thanks Byron, yeah I love that table as well, just wish it was a little bigger, oh about 4'x8' lol
Scott.
Camano510
Postby Camano510 » 10 Mar 2016 11:44
Love this thread. The pic of the engine in place..... Crazy-low center of gravity advantage!
Darryl Cavanaugh
71 510 2dr father/son project
Track Junky
Postby Track Junky » 27 Mar 2016 04:48
Finished up the control arms this weekend. Everything went as planned and really happy with how things turned out. The inclination angle on the bottom control arms are a bit off due to the outer ball joint not tightened and seated in the taper. Cant wait to get this off the build table and on the ground.
Scott.
Track Junky
Postby Track Junky » 17 Jun 2017 17:56
So its been ages since I updated mu build. Took a bit of a break from the 510 working on other projects around the shop, some big, some small, lots of paying (which is always nice)but the past few months I made quite a bit of progress, Managed to get the front suspension/steering completely done, really happy with how all that turned out. Rear is all fabbed and set up as well! Chassis to body mounts, engine/tranny mounts, etc.. and off the build table and on the ground! for the first time ever!
Scott.
510wizard
Postby 510wizard » 18 Jun 2017 08:08
Congrats!
Heinrich
Postby Heinrich » 19 Jun 2017 00:47
well done
Users browsing this forum: Bing [Bot] and 1 guest
