Scotty's 13bpp '71
Track Junky
Re: Scotty's 13bpp '71
Post by Track Junky » 26 Jul 2013 14:41
goichi1 wrote:Damn that's cool! very nice! Are you going to have it balanced? or do you think it would even matter??
Not sure Rich! I will let my tuner find out on the engine dyno aha!
Scott.
Post by Byron510 » 28 Jul 2013 08:19
Scott.
It does all matter in the world of balance. Harmonics are a bad thing. The pulley complete should be mounted to the crankshaft when the balancing procedure is done.
Great job on the mill Scott. I'll bet you had a sore arm after all that rotary table and dividing head cranking! I've got a little 4" chuck that I mount on the rotary table at work, also to keep the height down. But that mill has about 20" to work with. You do what you can, and your work looks great.
Aluminum is a wonderful material isn't it.
Keep us posted.
Track Junky
Post by Track Junky » 29 Jul 2013 17:47
Cheers Byron! Yeah my forearm looks like popeye from all that turning! ha! I was only doing .050" depth cuts with an .500" end mill at slow feed rates!
Aluminum is like butter compared to some 4130 tubing I was cutting for my bicycle fab stuff!
Scott.
Track Junky
Post by Track Junky » 11 Apr 2014 11:21
Decided to scrap the tubular rear set up and go with a full IRS double wishbone rear. I have a plan, a welder, a new platen table, and some starting material :)
Should start sticking things together in a few weeks!
Scott.
Post by 510rob » 11 Apr 2014 12:24
big smiles - I am eager to see what you come up with - no doubt it will be high grade
Track Junky
Post by Track Junky » 23 May 2014 14:13
Small update:
Started on the lower control arms of my double wishbone IRS.
I had some 1-3/8" Hex stock that I used as camber/toe adjusters turned down and threaded to accept my 1/2" rod ends on the inners and 5/8" on the outers.
They fit inside the sleeve next to it in the pic.
Assembled, just need to get some jam nuts to hold things tight. Miters came out super nice, they hold water!
After I build the upper and lower arms I will start on the cradle thats gonna hold the R180 LS out of a late model STI.
Pics to come......
Scott.
Post by two_68_510s » 23 May 2014 16:44
Lovely
Cmac
Post by Cmac » 11 Oct 2014 07:43
How are those new trailing arms working out?
Track Junky
Post by Track Junky » 11 Nov 2014 17:37
Hey Cmac. No news on the IRS rear besides my design tweaks, but great news is Im so close to closing on my own shop, I dont want to jinx myself so I will leave it at that.
Scott.
Sleepys-14
Post by Sleepys-14 » 11 Nov 2014 19:29
Make sure you mount the diff as high as you can, or you are only solving half the issue back there.
Track Junky
Post by Track Junky » 12 Nov 2014 03:17
Sleepys-14 wrote:Make sure you mount the diff as high as you can, or you are only solving half the issue back there.
Nope, gonna solve all the issues back there. This is going to be a total independant rear, meaning upper and lower control arms, none of the stock stuff or location points will be used.
Scott.
510wizard
Post by 510wizard » 12 Nov 2014 08:04
Love to see the shop pics when it comes about. Fingers crossed.
Track Junky
Post by Track Junky » 12 Nov 2014 09:39
510wizard wrote:Love to see the shop pics when it comes about. Fingers crossed.
Thanks!
Scott.
Track Junky
Post by Track Junky » 15 Dec 2014 17:33
So I finally closed on my new shop, cant wait to move the 510 into her new (heated) home! Big move ahead, loads of shit to move/build/organize etc....
Scott.
Post by 510rob » 15 Dec 2014 21:08
congrats!
