Bike carbs... WHA?!?
zuum510
Post by zuum510 » 09 Dec 2008 17:08
Removed due to lack of dyno sheet
iceD
Re: Bike carbs... WHA?!?
Post by iceD » 09 Dec 2008 19:16
This is interesting. Have any of you geniuses done the math an this one?
ice D 8)
CorAce
Post by CorAce » 09 Dec 2008 19:48
Wow, gota say I'm intrigued. I would be interested in the info of the shop that made the manifold. Have you had it on the street yet? How does it perform? Will the stock fuel pump feed it?
car more gooder then book
spoolinitup33
Post by spoolinitup33 » 09 Dec 2008 20:23
Hey, that's what my car had on it when I got it. Well, kind of. It was kind of a back-woods mechanic that did this to the original engine, and it wasn't the same carbs, but it's pretty much the same concept. I think it was these carbs. that they used, just older ones: http://www.fastbygast.com/Catagories/Pr ... ncarbs.asp I should have kept them and tried to sell them.
510ER
Post by 510ER » 09 Dec 2008 22:51
That thing sounds bad ass! nice work! If you dont mind me askin what did the shop charge to build the manifold?
Spokane, Washington
71 2dr L20b stroker project
77 620 Looong box *sold used $$$ for rear coilovers and LSD
slodat
Post by slodat » 09 Dec 2008 23:51
510ER wrote:That thing sounds bad ass! nice work! If you dont mind me askin what did the shop charge to build the manifold?
+1
'70 510 2 door
chopped '69 521
Post by okayfine » 10 Dec 2008 08:21
Dyno test. Otherwise it's just pretty.
Yer not a pretty boy, are ya?
Post by Byron510 » 10 Dec 2008 09:37
he motorcycle carb install has been done to 510's quite a few times. The couple set ups that I've seen in person were pretty rough. I remember a local car that had 4 Mikuni bike carbs on back in the early 90's. At that time I didn't see the point as Webber, DelOrtto’s and Mikuni PHH cars were some plentiful. However, now that the twin choke side draft market is getting a little niche, I can see why you'd do this. I makes more sense these days.
Nice work, good to see you posting here. I like the use of recycled Datsun bits like the intake manifold flange and the braided rad hose rubber! :D the motorcycle throttle cable splitter is a great idea – might have to keep that one on the books as well.
Keep us up to date on how it works out.
zuum510
Post by zuum510 » 10 Dec 2008 18:41
If you are interested in having a manifold made, contact Jason at
Forward Motion
http://www.turbo4g63.com
Jason@turbo4g63.com
253-324-6690
10313 B Lakeview Ave
Lakewood, Wa 98499
1971 510 Wagon
Post by okayfine » 11 Dec 2008 07:38
zuum510 wrote:Sure thing, but you gotta pay for it... :lol: This is gonna be a driver and sometimes race car... but I could honestly care less how much power the L16 is making (it is supposedly built by rebello... but its still a L16 :roll: )
Did you re-jet the carbs?
I sure cared about how much power my KA was making when I tried ITBs. When I confirmed I was making less power, off they came to sell them on eBay to someone who didn't care how much power they were making.
rnorrish
Post by rnorrish » 11 Dec 2008 07:49
Julian,
which ones did you use?
richard norrish
CorAce
Post by CorAce » 11 Dec 2008 09:13
The part of the article that talks about the R1’s 35-degree angle and some thing about a Rover is cut off. Do they or don’t they work well at less of an angle? I could see having hood clearance issues with my L20B and that setup.
Post by okayfine » 11 Dec 2008 09:32
rnorrish wrote:Julian,
Suzuki Hayabusa and GSX-R 1000s. I tried both.
DQ Volume 6 Issue 3 - Individual Throttle Body Conversion: A Dimer's world is not the path of "factory stock." There's always something better out there and good enough usually isn't. Even modern engine swaps are not immune to our need to improve beyond stock. We’ll show you how to keep your EFI yet reduce weight, improve access, and more importantly, increase airflow by bolting on individual throttle bodies.
and
DQ Volume 6 Issue 4 - ITB Conversion: Part Two: The end of Part I brought about questions concerning the electronic side of things, specifically, what would happen to the air/fuel mixture because of the ITBs and would the stock ECU be able to handle the additional air flow. I'm sure you're also wondering about power gains. I know I was!
Dyno here:
http://www.jetlink.net/~okayfine/sedan/ ... ound_2.gif
Basic info here:
http://www.jetlink.net/~okayfine/sedan/ITBs.html
Apologies for the thread-jack - here.
Post by okayfine » 11 Dec 2008 09:35
CorAce wrote:The part of the article that talks about the R1’s 35-degree angle and some thing about a Rover is cut off. Do they or don’t they work well at less of an angle? I could see having hood clearance issues with my L20B and that setup.
It's likely due to the floats. The carbs are designed to fit at that angle on the bike, so the angle needs to be maintained on whatever application you use them on. Just as the angle needs to be maintained on a set of SUs.
Floats don't work very well when they hang up against an angled float bowl.
johnbureezu
Post by johnbureezu » 11 Dec 2008 09:59
If I ever put MC carbs on my car, they're going to have to be keihin FCRs. Almost put a set on my honda back in the day. They only work good at high RPM...hence being for motorcycles.
Flatslide baby!
