gooned
Post by gooned » 08 Apr 2019 22:24
Killing it...nice tip on the FH bolts too.
Heinrich
Post by Heinrich » 10 Apr 2019 07:32
WOW, extremely nice work work on the pie cut pipes(well everything really)
CV Driveline
Post by JordanTr » 08 May 2019 21:03
I posted a picture of the raw parts before but I recently made CAD models of them to try to plan what sort of weld interface I could make work.
It's an early (I think) S13 slip yoke with w BNR32 driveshaft CV flange from the halfway point.
Pretty much the largest weld interface I could manage is about 1.75" diameter.
ImageS13 by TRZ Fab, on Flickr
ImageYoke Xsection by TRZ Fab, on Flickr
ImageCV yoke by TRZ Fab, on Flickr
With 1/4" conservative weld width, 300HP @4400rpm (optimistic, I know), and 1st gear 3.321, there's only 6,000psi of weld stress so that leaves a good margin for burnout shenanigans etc.
I watched a few YouTube videos on it to get some ideas. Video 1 , Video 2
Their general theme seems to be 4 quick tack welds.
I've pieced together the following idea thus far:
-Machine to suit 3 thou interference fit.
-Assemble with ~1/16" gap and shoulder and hammer pieces true in a lathe
-Preheat to 300F
-Tack weld 4 spots rapidly
-Roboticize the MIG welder and weld out on rotary table
-Air cool and cross fingers
What I'm looking for are some thoughts on how to ensure this beast stays true throughout the welding process.
Anyone done something similar to this before and have feedback?
Post by icehouse » 09 May 2019 09:43
Why not just bolt it?
datsuntech
Post by datsuntech » 09 May 2019 09:56
I used to work in a driveline shop building driveshafts all day. Industry standard was .007" runout, we used .005" runout as our standard. This made it so that no balancing was necessary although we tacked a small weight on the low side so customers wouldn't complain. Of course this was 4.5" 1/4" wall tubing, but we used the same spec on small stuff too. As far as assembly we put 4 evenly spaced tacks around the tubing on both ends rechecked the runout with a dial indicator and then hand MIG welded each end while hand spinning the shaft on centers. Leave to air cool and they came out dead straight. This is Heavy duty mostly so much more horsepower and torque than your average car. Never had a weld crack or break.
Now I don't know if this is helpful at all, but that's how we did it. Any questions, feel free.
Post by bertvorgon » 09 May 2019 10:26
My first hand experience...Andy made my drive shaft in the lathe, carefully did basically what datsuntech said, and I have NO balance weights and NO issues after 20 years of use.
Post by JordanTr » 10 May 2019 20:19
Thanks for the comments. I really appreciate some real world experience with this stuff. That all makes good sense. I will have a look at the bolted option because it does take a lot of the finesse out of it. Sounds like an over coffee project for tomorrow. I don't have abundant machine shop access so I'm trying to work with what I've got. I'm all ears for a CNC shop that does one or two off stuff too!
qship510
Post by qship510 » 10 May 2019 22:08
More firsthand experience; what you are building is very similar to the way I have built CV stub axles and flanges. Cut down VW bug output flanges to get the CV mounting surface, then machine 510 stub shafts and axle flanges to press-fit the machined VW output flanges. Center everything up in a lathe and tack, check runout and adjust, then finish weld. Just for kicks once the welding is complete I used a rosebud torch to heat the whole assembly up to "red hot" and let it air cool. Built my first set 22 years ago and they are still running strong. Stephen Pepka gave me the recipe back before all the bolt on options became a reality.
Post by JordanTr » 11 May 2019 21:20
Great thanks. I think I found another way to make it work without the welding and all the finesse that goes into that. I should be able to get some parts machined that will allow a simple bolt together assembly with a press fit center to maintain concentricity. For scale, the bolts shown are M12x1.25 Class 12.9 SHCS.
If I go through with this and get these flanges CNCed, is there any interest out there for a CV slip yoke?
Because we are all here for pics:
ImageBolt Yoke by TRZ Fab, on Flickr
ImageBolt Yoke End by TRZ Fab, on Flickr
ImageBolt Yoke Xsection by TRZ Fab, on Flickr
The good news is that I'll be able to just shorten my existing driveline to add the front CV joint onto it! 8)
Post by icehouse » 12 May 2019 21:18
Cool!
66DUCE
Post by 66DUCE » 12 May 2019 22:19
Jordan, I think I noticed you had a wanted add on C/L for another 240sx driveshaft? I have one if you are interested. I will put my hands on it on Tuesday if that still works for you?
Post by JordanTr » 13 May 2019 05:13
66DUCE wrote:
12 May 2019 22:19
Yep, guilty lol! Sounds great. Just shoot me a PM if it’s a goofy 3 bolt one and we can go from there. Thanks!
Post by JordanTr » 06 Jul 2019 07:22
I’ll just leave these pics here for now. Full update later!
Post by 510rob » 06 Jul 2019 13:06
that brakeline? is a work of art. :P
Heinrich
Post by Heinrich » 06 Jul 2019 23:35
510rob wrote:
06 Jul 2019 13:06
HAHAHA
