Black and Blue '68s
Re: Black and Blue '68s
Postby okayfine » 10 Oct 2015 08:17
Dual brake masters on the 3-wheeler.
I can ship you one set of bits. PM me your digits. These were just sitting on the shelf, waiting for someone to need them; renumeration not necessary.
Postby two_68_510s » 29 Oct 2015 19:09
okayfine wrote:Dual brake masters on the 3-wheeler.
Worked perfectly, I will have pics when assembled, thanks again.
Postby two_68_510s » 29 Oct 2015 19:16
Hey, I have a question. I am making a new connector from carbon fiber board 3/8" thick to bond to the intake plenum, and then the throttle body bolts to this piece. This TB has a progressive setup with two sizes of throttle bore. Should I join the two holes as in the second pic, or leave them separate like the first pic?.
carbon plate.jpg (147.45 KiB) Viewed 1237 times
Postby RMS » 29 Oct 2015 23:18
I really need to reed Engineer to Win and Prepare To Win by Carroll Smith and this that I just foundhttp://www.intechopen.com/books/advances-in-internal-combustion-engines-and-fuel-technologies
Postby RMS » 30 Oct 2015 14:56
Ok my brain hurts after reading chapter 1 of the Advances in the internal combustion engines......I need to read Sir Harry Ricardo's the high-speed internal-combustion engine and Experimental and theoretical investigation of turbulent burning model for internal combustion engines by Norman C Blizard to up my comprehension of the before mentioned book.
Postby okayfine » 30 Oct 2015 15:46
Joel, if the OE plenum (or, more particularly, your new plenum) just combined the flows from the big and little bores, I don't see a particular reason to go one way or the other. The B/l bores aren't kept separate in the plenum, no need to keep them separate at the mounting. Do you know what page(s) the TB you're using was shown?
Postby two_68_510s » 30 Oct 2015 15:49
I admire your ambition, I am more of a empirical data kinda guy, guts you know! I was hoping to tap into the gut feelings of more experienced builders like you all, and get your feeling on it. Can't afford to model the thing.
Postby two_68_510s » 30 Oct 2015 15:56
okayfine wrote:Joel, if the OE plenum (or, more particularly, your new plenum) just combined the flows from the big and little bores, I don't see a particular reason to go one way or the other. The B/l bores aren't kept separate in the plenum, no need to keep them separate at the mounting. Do you know what page(s) the TB you're using was shown?
Pages 140 and 141 Corky Bell's "Supercharged"
Postby RMS » 30 Oct 2015 16:18
I lean towards joining
with your injectors so close to the valves I see no need for unnecessary turbulence(no gasses being mixed in the plenum)before the velocity stacks (witch should add to the ram effect). the rotational brush you left on the stacks should add micro eddies to propagate mixing as the charge swirls around the valve and into the combustion chamber.........I think :?
Postby two_68_510s » 30 Oct 2015 17:14
Also, Julian, I really was wondering if extending the throttle body tube length would make a difference. I am sure it is a tiny difference in any case.
I lean toward opening it up and doing a kind of radiused lip on it, like the horns.
Postby two_68_510s » 30 Oct 2015 17:19
[quote="RMS"]I lean towards joining
Just the air, you are right. I think I agree with joining.
RonM
Postby RonM » 03 Nov 2015 12:12
Always a lesson to be had when I peak in on your build Joel. If theoretical energy were measured in octane, your thread would be top fuel for sure. Intellectually challenged as I as, I usually come away with a headache from this stuff, but everything you are doing here is presented in a down to earth, understandable way. Fun read.
Postby two_68_510s » 03 Apr 2016 01:06
My Neuspeed progressive throttle body requires a bracket to hold the throttle cable.
I am using a Lokar setup, very simple and well made. They provided a generic bracket that wouldn't work for me.
Probably could have been simpler but what fun is that?
3mm aluminum plate some wierd heat treat left over from some armor testing??
view 2
I threaded some existing holes in the body to hold the bracket
5mm Ti screws
Lokar stuff is good
Strongback
View from the side
greenthumb
Postby greenthumb » 03 Apr 2016 08:13
nice custom fab work Joel! I can ony imagine how many hours you have unto that piece!!
Postby two_68_510s » 03 Apr 2016 08:16
greenthumb wrote:nice custom fab work Joel! I can ony imagine how many hours you have unto that piece!!
Yeah, if I was doing it for a living I would be out on the street!! Thanks Henk!
Users browsing this forum: Yahoo [Bot] and 7 guests
