Black and Blue '68s
Re: Black and Blue '68s
Post by RMS » 16 Aug 2015 09:52
thats beautiful joel! I wondered how you would get er dun.
Post by two_68_510s » 20 Aug 2015 20:25
Finished the "scoop" for the supercharger oil cooler. Used the existing splash guard and a piece of an old fender to make the scoop.
Post by 510rob » 20 Aug 2015 23:45
holy!
Post by two_68_510s » 21 Aug 2015 06:42
510rob wrote:holy!
:lol: :lol:
Post by two_68_510s » 02 Oct 2015 19:40
I am still putting together the engine compartment and found a point of interference! The brake MC and booster combo pushes the front reservoir into my throttle body position. Can I put a remote reservoir nearby, and is there a kit somewhere that will adapt to a Datsun MC? I happened to have two sizes of reservoir (sitting on plenum core but they are both too tall)
Post by Byron510 » 02 Oct 2015 22:07
Will the Tilton remote M/C part help Joel here? I installed these on my car, and they looked exactly like the Datsun ones. But I cannot measure both as I don’t have them.
Also Mazda trucks of early 70's vintage came stock with the same type of component on a Nabco M/C.
Just a thought.
10-2-2015 10-04-41 PM.jpg (38.33 KiB) Viewed 1165 times
Post by two_68_510s » 03 Oct 2015 08:55
That looks perfect, thanks I will look for that piece.
Post by two_68_510s » 03 Oct 2015 19:35
Does anyone know or can measure the size (outside diameter) of the place on the Tilton Model 74 M/C where the reservoir clamps on?
I can't seem to convert this file into something I can measure on the computer.
Tilton 74 M/C measurement
Post by two_68_510s » 07 Oct 2015 20:30
See above ^^^^^Anybody?
Post by 510rob » 08 Oct 2015 02:31
Joel, I measured one of my Wilwood "Combination Remote Master Cylinder" masters, and it came up as 1.347" and 1.349"
http://www.wilwood.com/MasterCylinders/ ... 20Cylinder
http://www.speedwaymotors.com/Wilwood-C ... ,1133.html
...are the Tilton 74 series the same as the very-similar-in-appearance Wilwood product???
Post by okayfine » 08 Oct 2015 06:35
I may or may not still have some Wilwood remote BMC bits-n-bobs...
Post by two_68_510s » 08 Oct 2015 21:18
okayfine wrote:I may or may not still have some Wilwood remote BMC bits-n-bobs...
I will measure the stock unit to see if it is a standard measurement.
Post by two_68_510s » 08 Oct 2015 22:02
I measured the stock Nissan M/C and I got 1.365". What is the inside diameter of that remote gizmo you have. I seems we are about .02" or so off.
Post by okayfine » 09 Oct 2015 12:14
My bits measure 1.350" ID. A little action with a heat gun should see them on without issue. Here's my box of stuff leftover from the 3-wheeler:
Post by two_68_510s » 09 Oct 2015 16:01
Yes indeed, looks like you have two complete setups at least. Clutch and Brake?
Anyway, I would only need one group of gizmos. Would you be willing to part with some of that? Renumeration would be in order, let me know.
