Ahhh the unicorn huh? Lolokayfine wrote:There has been mention and links to a molded 510 carpet. I don't know anyone that's purchased it.
PoorMtnKids 70 2DR
- PoorMtnKid
Re: PoorMtnKids 70 2DR
Looks great in that Vegas sun!
I need to go back to verifying my links and memory before posting. The main return for molded carpet for the 510 now only lists "cut and sewn" carpet when you click on it.
http://www.stockinteriors.com/items.asp ... 510_Carpet
They talk about molding it in the link, but that's not what you can buy, so...
Says molded here, but no pictures:
http://www.andysautosport.com/carpet_ki ... n_510.html
I used that carpet in the coupe, it fit pretty good, little trimming and it goes right in. I was happy with it.
At $159, it seems like a good price.
I used the stock interiors kit. I would rate it a 9 out of 10.
- PoorMtnKid
I ordered the kit so it should be here tomorrow. Over the weekend I started to install my head liner. Along with that I got my rubbers from datsport started. The trunk, or "boot" as they call it is in and the main door seals are in. Its getting closer to being back on the road!
- PoorMtnKid
Got around to installing my fuel cell. Due to starvation issues and my shitty weld job of the 300zx pump to the stock tank, I decided to have one custom built to fit the stock mounting location. If I knew Julian was going to be selling his I would have totally swooped that monster up. This one by my calculations should be 10.5 gallons or so.
Only thing I need to do is mess with the filler neck to get it to mount right. BP Joel allowed me to test fit with his all rubber one that was took short, so that one may b perfect. Going to Washington DC tomorrow night so I will mess with it more next week.
- PoorMtnKid
I was so close to getting my car back on the road for "510 Day". I worked on buffing out my chrome trim for the windows and getting those installed. Installed door handle on the passenger side and also the side mirrors for both sides. All panels are in except for the driver side due to needing to install the new door handles. After getting my fuel cell buffed out and installed I worked on the fuel pump and lines. I got everything mounted the way I wanted. Put in about 3 gallons of gas and went to start. After letting the pump prime we noticed no fuel was getting pumped into the inline clear fuel filter before the pump. Low and behold the pump was bad which was purchased from Jegs!! So I have to send that back and get a new one.
Love the wheel/tire combo with that stance - looks great.
Look forward to the updates.
do you have a pic of the clear fuel filter? are you sure it's rated for high pressure fuel injection? just curious, I was thinking about getting one too. Thanks.....
- PoorMtnKid
The fuel filter or the pump being rated for High Pressure? The pump is, it was sold as an EFI fuel pump. Here is a link to the filter- http://www.jegs.com/i/Fram/410/G3/10002/-1goichi1 wrote:do you have a pic of the clear fuel filter? are you sure it's rated for high pressure fuel injection? just curious, I was thinking about getting one too. Thanks.....
- PoorMtnKid
Thanks! I got a new pump coming here by Wednesday from jegs. So hopefully I can get it running so I can take some pictures out in the sunlight.Byron510 wrote:Love the wheel/tire combo with that stance - looks great.
Yea, I was talking about the clear filter, I would not use that filter for a fuel injected car, the pressure is too high for that. You should get a filter rated for a the pressure. You don't want a line to blow off or the plastic to crack, that could be bad. I am pretty sure the filters on injected cars have more filtering capability too.
EDIT: I read back through, I see that you put it before the pump. Not sure I would still use it, but maybe it will be ok.
Also, if you are only using a high pressure pump to pull the gas out of the tank, those pumps don't really work for that. They don't have the ability to pull fuel in. You would need to have a pump like this to supply fuel to your high pressure pump.
https://www.pegasusautoracing.com/produ ... RecID=8462
Plus this one has the flow through design, where fuel can flow through it when it is off also.
