Really Ratty Rusty Ruby RIP
indy510
Re: Really Ratty Rusty Ruby RIP
Post by indy510 » 12 Oct 2012 01:27
Okay, "now" this is starting to get fun .... :lol:
indy510
Post by indy510 » 12 Oct 2012 01:31
This seems like a good place for the motor .. except the oil pan's on the ground, the hood won't shut, and the "frame" can go 2" lower
Nice and far away from the firewall... :cool:
indy510
Post by indy510 » 12 Oct 2012 01:35
Time to take everything apart ....
GREG510
Post by GREG510 » 12 Oct 2012 01:50
Dry Sump :lol:
indy510
Post by indy510 » 12 Oct 2012 01:54
But the transmission's on the ground too .... :evil:
proflex wrote:Hood scoop :wink: ............................
NEVAR!!! .... :lol: ..... I'd rather hack the firewall till the roof caves in .... :roll:
and BTW,, the firewall/windshield wiper area is VERY structural... right up there with the frame rails and rocker panels
indy510
Post by indy510 » 12 Oct 2012 01:59
indy510
Post by indy510 » 12 Oct 2012 02:06
Post by Byron510 » 12 Oct 2012 12:43
indy510 wrote:
I have a plan .... :twisted: .. . raise the car?
No!!! :shock:
Can't be done... how about a twin sidedraft set up on a rotary - I've never seen a more worthy low profile engine - including the oil pan... unless you go boxer on us :lol:
There is will, let's find a way!
http://atkinsrotary.com/store/Performance-Intakes/
I know that someone made a twin sidedraft that went beside the motor and strut tower, but I can't find a photo. the reason I know one was available is that when I worked at an un-named speed shop in my youth, they installed one in an Gen I RX7 - it was a pretty cool set up.
Post by okayfine » 12 Oct 2012 14:11
Dry-sump and one of Dave's cowl-induction hoods. Don't make it hard on yourself.
Post by 510rob » 12 Oct 2012 16:13
okayfine wrote:Dry-sump and one of Dave's cowl-induction hoods. Don't make it hard on yourself.
...because dry sump is easy (and cheap?)
:shock:
Post by okayfine » 13 Oct 2012 09:17
I'm not sure anything Indy's done has been easy. My comment was more in line with Indy's ultimate goal of lowness. Everything else is secondary (or doesn't even matter). With that in mind, what's some mo' money when the solution is available?
indy510
Post by indy510 » 13 Oct 2012 10:07
Easy? .. no ..... Done right/correctly/qualityly?? ... no ... :lol: .... .. .. cheap? .. asside from welding wire/gas/metal ... yes
I started this project with a "goal" of raising the rear suspension/floor only 2 inches, and somehow get one inch more clearance for the front ... I ended up raising the rear floor 4" and front frame rails 3" ... Niether of these numbers are "crazy" new concepts for the 510 world. Many 510 race cars have the front LCA's raised 2.5",, and by raising my rear floor 4", I will still have some negative camber at a "normal" 510 race car ride height.
IMO a "normal" 510 race car is as low as I used to drive this car, with the front X-member 2.5" off the ground and the rear rocker panel seams 3.5" off the ground... I was dragging the exaust, oil pan, frame rails, front and rear floor pans, rockers, and the rear x-member mounting studs .... But when I raised the car one inch fr/rr it would stop all dragging, and make the car actually fun to drive.
okayfine wrote:My comment was more in line with Indy's ultimate goal of lowness. Everything else is secondary (or doesn't even matter). With that in mind, what's some mo' money when the solution is available?
I know it seems like all I care about is "lowness" . :lol: . sometimes I do .. but having a motor sticking through the hood is where I draw the line
I don't see how a dry sump would help this?? .... . the bellhousing is already on the ground:
Post by okayfine » 13 Oct 2012 11:49
Fair enough. But is the rear of the trans where it wants to be relative to the diff?
Post by 510rob » 13 Oct 2012 13:54
If you install a dry-sump system, you can almost sit the engine on the ground the next problem is the bellhousing size, so then you need to get a small diameter flywheel, then cut down the lower extensions of the bellhousing The stock Datto ring gear is typically 120 teeth, whereas the typical small diameter QMI & Tilton flywheels are 94 teeth, giving you another inch or two of ground clearance to drop the car/engine a bit lower...
...but that stuff is quite expensive!
Dave Patten
Post by Dave Patten » 14 Oct 2012 13:24
I wrote an article for the Dime Quarterly about dry sumping my L20B powered racecar. It was quite the experiance getting it right.
The article is available on line (Thank you Julian) DQ Volume 8, Issue 4
Link: https://docs.google.com/folder/d/0ByCvx ... M4M2RiMDY1
Dave Patten
http://www.FutoFab.com
Dunbarton, NH
