Topher, SR 72
Re: Topher, SR 72
Postby okayfine » 23 Mar 2013 12:49
topher88 wrote:What do you guys think?
Given the money invested, I'd figure out a way to pressurize the oil system prior to start-up. Just spinning the engine and hoping it builds pressure (even with plugs removed, or coil disconnected) doesn't seem like a smart move. I've never been able to spin up pressure in my KA and SR after they sat, drained, and you can't do it with a long screwdriver like you can with an L or a KA/E.
I showed a couple basic pictures of the pressurizer I use in a near-the-end issue of DQ. 10psi or so, wait for the oil to dribble out of the cam lobes.
As an aside, by turning over the oil filter you can fill it up before you spin it on, as I mentioned above. This takes care of quite a bit of the issue during oil changes.
PoorMtnKid
Re: Topher, SR 72
Postby PoorMtnKid » 27 Mar 2013 12:20
I was just looking over your build again when I came across your gauges. What size did you go with 3 3/8 or the 4?
topher88
Re: Topher, SR 72
Postby topher88 » 09 Apr 2013 09:04
All that's left is bleeding the lines :)
Moved the filter out of the hot air
topher88
Re: Topher, SR 72
Postby topher88 » 09 Apr 2013 09:05
PoorMtnKid wrote:I was just looking over your build again when I came across your gauges. What size did you go with 3 3/8 or the 4?
Yes they are the 3-3/8
Re: Topher, SR 72
Postby goichi1 » 09 Apr 2013 20:33
topher88 wrote:All that's left is bleeding the lines :)
Looks like you need a throttle cable too!! :wink:
topher88
Re: Topher, SR 72
Postby topher88 » 10 Apr 2013 08:51
Bled everything. All that's really left is flushing the fuel lines, add coolant and wiring!
topher88
Re: Topher, SR 72
Postby topher88 » 10 Apr 2013 08:52
Already done ;) it was disconnected to tighten a ever so slightly seeping brake line fitting
Re: Topher, SR 72
Postby goichi1 » 10 Apr 2013 15:31
Looks great too!! Now take that silicone throttle body boot off and trim it straight!!! It makes the eyes draw to it. Attention to detail man, the rest of it looks killer clean!! When you do your wiring, make sure you tuck it good, it just looks too clean to leave anything hanging out there. Simple always looks nice!
topher88
Re: Topher, SR 72
Postby topher88 » 10 Apr 2013 15:41
Lol don't worry that 90 is on the large "to do" list. Number 1 on that list is to get it running. Then in my spare time do touch up paint and little things like that 90
topher88
Re: Topher, SR 72
Postby topher88 » 23 Apr 2013 16:18
Cars getting wired as of this last weekend :) hope to get it back by this weekend
topher88
Re: Topher, SR 72
Postby topher88 » 06 May 2013 10:19
Well she is alive! Already put over 500 miles on here the first week. Only one big issue tho... Where the head bolts onto the timing chain cover the engine builder didnt put rtv to seal it so it leaks. The builder is going to switch it out for me along with doing a couple other things so its not that big of a deal. She is in desperate need of a tune tho. Idle is a little ruf but I can tell by just boosting a little that its going to be a stupid fast car. So far all is going great and a few hundred more miles and an safc I should be ready to dyno tune :)
http://youtu.be/bFIXCQcUeHU
http://youtu.be/1t9WGoEJlpk
Brought the wheels back to all their glory
Driving family members around
Re: Topher, SR 72
Postby okayfine » 06 May 2013 10:49
Keep on truckin'!
Re: Topher, SR 72
Postby goichi1 » 06 May 2013 12:55
Nice!! Glad to hear its running and driving! This gives me motivation to get mine done! Hammer down!!!
akara
Re: Topher, SR 72
Postby akara » 10 Jun 2013 19:18
Wow your car has really transformed since the last time I saw it! Keep up the awesome work!
Andrew
johnbureezu
Re: Topher, SR 72
Postby johnbureezu » 11 Jun 2013 09:36
see you at nissan jam bud!
