So I started working at a local tuner shop ran by a friend of mine. The benefits are that I now have access to high quality tools, a lift, and space to take the car apart if needed for the project (I live in an apartment).
Last night was a late night in the shop waiting on a local parts store to send over a rear main seal for a customers car. Anyway, after that ordeal we threw my car up on the lift and took care of installing some of the parts I had been hoarding for the last month or two. We installed a set of Troy Ermish front coilovers on 280zx struts and brakes, stainless brake lines, and Aero 13x7 +0 rims with the slightly stretched 155/80s on them. I wish the rubbers were 155/55 or 65s, but I already owned them so it will have to do until they wear out. Then I can buy something with a little better sidewall profile. I had some issues with the drivers side 280 caliper as the stainless line wouldnt thread into it. It seems like the first two threads were stripped slightly so after a little manipulation we got it sorted out and fitted right.
Everything else went pretty smoothly. Adjusted the coilovers to a height I liked and took the car off the lift. Turns out it wasnt low enough... so it needed moar loar. Dropped it down another couple inches to a better height. Now the car has a bit of a rake to it. Unfortunately with the rears being so soft and the extra inch of rim I added, the tires rub if theres even a moderate amount of weight in the back. Theres no way I could even carry a single person in the rear with the way it sits right now. Even 70lbs make the rears rub. So now Im on the hunt for a good setup to fix the rear. Any ideas?
Anyway, here are some pictures:
New rims on stock suspension and height
Side poke on stock suspension and height
Stock suspension
280zx suspension
Side poke on 280zx suspension and lowered height
New rims with lowered height
Profile view to include all new parts installed and front lowered
When I ordered the rims, I ordered a set that were completely black without the yellow stripe and for whatever reason those were the ones that showed up. Unfortunately, I didnt open the box until I went to mount and balance the tires so I didnt notice. The Aero logos on the rims are stickers so Im just going to Goo Gone them ro remove them, but Im not 100% sure what I want to do about the thin yellow line. I still have to completely refinish the stock bullseye hubcaps before I mount them to see how they look. So far I really like just these (with the exception of the yellow). I want to thank Paul for all the suspension components I picked up. They were in great condition and worked out phenomenally.
If anyone local to the Seattle/Tacoma area would like a set of stock 510 hubs and brakes I have them available. They are stock components so its really not worth it to ship... but if youre local and need them let me know as you can just have them.
