Fake Rusted Bondo and Fiberglass
10 years and a 100 things you shouldn't do to a 510 later ......
the 2 door got parted out in May 2011:
Re: Fake Rusted Bondo and Fiberglass
the 4dr's "bad" rust:
the 2 door has better floors,,,,
I grabbed all the parts off the 4 door.....
shortened 510 struts with adjustable MR2 inserts ......
the 2dr "had" rear disc brakes ...... .. so all the drum brake pieces are gone / no brake lines
... . and I needed to pull the rear crossmember out of the 4 dr anyway, to fix the rust ... .. so I swapped the whole crossmember/diff/half-shafts
This was supposed to be a 2 week 510 swap (every bolt/part) ..... . the taking apart takes 0.10% of the time as putting back together .....
1994 Honda Prelude seats:...... . .. they're in great condition because I got them in 2002 .... ..... low miles
This is how it looked ten years ago:
and for the first time in over 15 years it has a pre 79 510 dash .....
The white was just half a quart of thinned rustoleum in my touch up spray gun and 3hp compressor....
...... I let it sit for a couple months,,, ,, then wet sanded it with 320:
It's "fake" rust ..... .. a chemical reaction over the "powdered iron" base coat:
¿V-brakes on the mountain bike?
If it's a powdered iron base, and a chemical reaction, then why are you calling it fake? It's rust. Fake would be sponged brown paint.
