Noobie's 510 project
DADZSUN
Re: Noobie's 510 project
Post by DADZSUN » 23 May 2016 17:11
Really? I don't think it's *that* much roll - especially for a street car.
Having said that, I tend to prefer a softer car. Here's a pic of my BSP 350z on a FTD run at the 2006 Nationals.
DADZSUN
Starter question
Post by DADZSUN » 23 May 2016 18:32
Last year I had my starter rebuilt. Since that day I'd still get intermittent starter issues. It would be anywhere from 1-3 tries to get the starter to crank, otherwise I'd get a 'click'.
I took the starter out and brought it back to the rebuilder, they told me everything was in spec and showed on the test bench that it worked fine. I installed a relay to ensure the ignition wire voltage wasn't an issue. The problem persisted and I kind of lived with it to chase other issues.
That problem came to a head when the starter died altogether this weekend, during autocross no less. Yes, I push-started the car for each of my 5 runs and my son's 5 runs, plus one to get home.
In summary, I would get all of these issues with the starter:
  • 'clicks'
    a slow cranking action like the battery is nearly dead (it wasn't)
    a 'clunk' like starter pin would engage with the flywheel but not enough power to turn, and;
    nothing/silence like the battery was completely dead (wasn't lights were fine). Although it did intermittently start to work again later at home until again it died.
Battery voltage is 12.5v, ignition/small wire voltage is showing 12.3v when unplugged and ignition is in cranked position. When plugged into the solenoid the same wire shows 11.3v during ignition at crank (starter is NOT cranking) and the wire gets hot after repeated tries. Most telling I think, I tried shorting the starter by connecting the positive battery feed to the solenoid spade and all I got was one mini clunk then sparks.
Any thoughts as to what it is? I'm wondering if the start shows fine on the test bench under no load, but then starts to act up when loaded against a flywheel?
Post by bertvorgon » 24 May 2016 19:27
Sorry, I forget that not everyone has the same vision as I do, with an end goal the same. My car was built as a pure solo car.
DADZSUN
Post by DADZSUN » 26 May 2016 18:06
No need to appologize Keith. Your feedback is always appreciated and considered - as a result I'll be dialing up the compression on my Tokicos for the next event.
It turns out my starter issue was the solenoid. Thankfully the problem was reproduced at the rebuilder and after a quick swap I now have a have a perfect starter. It will be even more pleasant to take out for chores. :D
With the starter issue rectified, next on the Solo2 prep list is fixing the fuel that lightly drips out of the fuel filler line when cornering hard to the left. Its actually originating near the filler cap, from a slightly cracked vent tube that feeds from the top of the tank. Are there any 1-way check valves that can be pressed into the rubber connectors or something?
DADZSUN
Better torso retraint
Post by DADZSUN » 06 Jun 2016 19:37
The most recent autocross reminded me that I had to address the lack of torso restrain in the 510. Regardless of performance needs, the current shoulder belt is mounted so high that it's pretty much impossible to setup comfortably, or in a way to prevent eating the steering wheel in an accident.
Several ideas when through my head on how to attack this:
The first plan was to leverage the existing rear mounts on the C pillars. Perhaps using a direct-mount Schrother Rallye 3 belt.
That idea quickly failed when I realised just how low the mount was compared to the rear backrest - and I wasn't going to give up the back seats.
I then thought of building an elevated harness bar so the belts cleared the rear backrest.
Not bad but my 260z seats with their wide integrated headrest wouldn't allow the belts to sit properly over my shoulder. I could always purchase some harness slots and cut the seat, but if that failed things could get ugly quick. Vintage JDM bucket seat proved to be expensive and the width would be questionable for my 36" waist. :oops:
Eventually I abandoned that train of thought because the cost of new seats, the belts, and harness bar material would quickly mount. I needed something more cost effective. I decided to use the existing shoulder mounts and simply drop them ~8" to a reinforced location approximately mid-B pillar.
This new location is not ideal from a perspective of structural strength, but it is a far superior fit than before, and hopefuly the B pillars could shave some energy off before potential failure. Regardless, it's likely a toss up if the 40 y/o webbing would snap before the B pillars would flex/fail. Seriously, I'm going to get those rewebbed this winter.
It was a little scary drilling and cutting the B pillar but it actually went pretty good. I managed to re-weld the access slots with the same pieces of OEM metal. Slowly, my welding is getting better, that was thin metal with a good 1/2mm gap to fill.
The new location is perfect for casual & spirited driving. For competitive driving I'm still not anchored as much as I'd like, but the 260Z seat don't offer enough bolstering or frame stiffness to really expect more.
The passenger side was also complete. Almost looks OEM.
Post by okayfine » 06 Jun 2016 20:58
Bummer you didn't post up your problem and desire to get your stuff rewebbed. The gotbelts.com guys offer an OE-look latch belt with an 8" drop, which fits the 510 perfectly and is retractable. ~$180 for a pair, can't really be beat.
DADZSUN
Post by DADZSUN » 07 Jun 2016 05:11
okayfine wrote:Bummer you didn't post up your problem and desire to get your stuff rewebbed. The gotbelts.com guys offer an OE-look latch belt with an 8" drop, which fits the 510 perfectly and is retractable. ~$180 for a pair, can't really be beat.
Hey Julian,
Thanks for the suggestion but I was already well aware of gotbelts.com and after several conversations with the owner I realised it didn't fill my needs for several reasons:
  • The owner told me that their 8" shoulder drop belt is NOT fixed. In hard deceleration or an accident that 'virtual' shoulder mounting point (off the 8" drop) will pivot forwards before the inertia reel even begins to lock. That eats precious distance between my head and the steering wheel I'm looking to avoid, and it offers little to enhance the feeling of my upper torso being more secure during spirited driving. My new setup offers maybe an inch of free torso movement.
    Their $180 quote was for non-locking belts. If I recall it was another $50 or $230USD to get a locking mechanism which manually engaged the inertia reel. It sounded a little gimmicky, requiring me to reach back to the reel on the floor to engage, and only released when slack is introduced. Keeping my OEM setup allows for a more simplified cinching locked setup and total investment was only $20USD (rewebbing is about $120USD I believe).
    Gotbelts is not as clean. There's almost double the length in exposed belts and a large reel mounted to the floor. Yes, my new setup has an exposed hole in the headliner where the OEM mount was located, but I will purchase a painted cap to cover it for now. I hope to redo the interior/exterior when (if ever?) the kids move out.
    OEM setup offers more of an authentic feel which follows the theme of my 510. I purposely avoid power brakes, R&P steering and EFI to keep some 'engaging' quirks of the 510 era. Nothing is more quirky (sets the ambiance?) than screwing around with 3 belts when you first sit in the car.
No offense to those who purchased those belts. I'm convinced they fill a role for some projects which unfortunately wasn't in synch with my goals.
My setup has it's own flaws (potentially weaker mount and depending on 40 y/o belts), but for now the good outweighs the bad. I will likely send my OEM belts to gotbelts for rewebbing this winter, which will address one of the flaws. When I redo the interior I might further reinforce the entire B pillar to mitigate the other flaw.
Post by okayfine » 07 Jun 2016 06:07
Totally understand your points. It wasn't my experience (especially with the locking reel, I didn't have a manual switch and never saw that it was an option), but things could change since I last ordered last year for Barney.
Post by Byron510 » 07 Jun 2016 07:24
I always wondered what the rational was behind moving the belts up to the roof line on the 510. All 68's and I believe 69's in Canada came with the belt in the location where you moved yours to. Granted, there is factory reinforcement in the B pillar which was omitted once the mount location was moved. However I have never been given a good reason for this change having been made. Was it possible that the post simply wasn't strong enough?
At any rate, I agree with your change in mounting location. This effects taller guys more as we sit back further and the belt becomes a neck sawing device - most annoying!
I went back through my Ole Blue L 13 thread and found these two picture of the factory belt mount locations. As you can clearly see, the lower belt position works across my rather large frame -noted on the exterior photo.
DADZSUN
Post by DADZSUN » 07 Jun 2016 08:20
Thanks for the pics Byron.
Would you know if the 2 door has it's B pillar mounted further rearward? If so, that would have helped with fitment somewhat as well.
I'm curious as to the type of reinforcement you said was provided in the earlier models. Was it thicker metal, seam welding, or an extra brace that ran the full length of the B pillar?
Post by Byron510 » 07 Jun 2016 22:21
Yes, the 2dr pillar is 4" or so further backward.
I don't recall exactly what the reinforcement is, I just remember years ago noting that it was there. Anyone with a 68 or 69 with the lower belt points have a photo of their inner B pillar without the headliner in place?
indy510
Post by indy510 » 09 Jun 2016 12:06
I think I measured the 2dr door at 6" longer than a 4dr front door. But the pillars have a different angle, so the seat belt hole probably isn't exactly 6" further back.
DADZSUN
New filler neck
Post by DADZSUN » 15 Jun 2016 07:14
As I'm driving the car more this year than ever before, little 'issues' are becoming more prominent with accelerated wear. The smell of gas was previously subtle when driving hard but it became more noticeable this year, and that it occured on left hand turns. Andrew casually mentioned on my last visit about how fuel can slosh back up the filler neck and out the cap. In my case I think it was leaking out of the rubber connector just inside the quarter panel. A wet spot would always appear after an autocross run. Either way, it had to be fixed.
A quick (fun!) trip to the Kenny Pick N Pull helped me locate a donor. I felt like a perv peeking under dozens of car's rear wheels to see if their filler neck was what I was looking for. I eventually settled on a Subaru Outback (1995-1999) due to it's ideal vent tube location, larger piping size, and the fact that it was a Japanese make (along with my LSD).
A quick check at home showed that this had good potential.
I repurposed/welded the Datsun's fuel door front plate as a new backplate for the neck. I cut a new front cover plate for asthetic purposes only.
For the tubing, I used only the Subaru's piping and a small exhaust flare to match the tank's OD piping.
Once it was all welded up, I seam sealed the joins then tested with water to ensure no liquid would escape.
When test fitting I noticed the quarterpanel would flex surprisingly easy if I wiggled the filler neck, so I welded a brace onto the neck which bolts up to an existing hole on the chassis' structure. It's rock-solid now. You can also see the cork 'spacer' I fabbed to offset the door's inner lip which flared inwards, this allowed the filler neck's backplate to seat flush to the quarterpanel.
Once the brace's welding was done I POR15 everything.
The orientation of the trap door when mounted was pretty much bang-on. And yes, I'll purchase some matching bolts when I get the time.
A 'modern' gas cap to prevent to prevent leaking will be nice.
Overall I'm quite pleased with how the project turned out. I've removed a lot of rubber out of the equation, I have a hinged door and tight cap to control sloshing/leaking, and there's no issues with the trunk's hing hitting the vent tube. It took me maybe 4 hours of work and cost only $5 (not a typo LOL) for the Subaru part and approx $10.50 for the exhaust flare.
For the vent line that came off the charcoal canister to the filler neck, I simply capped it as the other line still vents out under the trunk.
DADZSUN
Lucas to the rescue?
Post by DADZSUN » 16 Jun 2016 10:07
My 510 is sooo close to being pretty much to the point that I could feel comfortable driving it across the country, or using it for DD if I had to.
My last hurtle is the lifters and their persistent noise. I've spent a fair bit of time trying to resolve this:
  • I've replaced all the lifters ($$)
    I've swapped oil from 10w30 to 10w40
    I replaced just the oil pump gasket
    I then replaced the oil pump
Each helped, but never resolved it completely. The new lifters gave me a quiet drive until the oil heated up & thinned out. Moving to heavier oil definitely delayed the onset of the ticking.
A new high volume (ie: KA24e) oil pump bumped the pressure up a bit and steadied things at higher RPM.
My latest (and hopefully final) attempt before giving up and dropping $550USD for mechanical lifters and cam was to try thicker oil 20w50. At Cdn tire I noticed a bottle of Lucas oil stabilizer which I've read as a potential solution for some KA24e owners. Rather than ditch the existing oil which is only 1000km old, I decided to try this solution first.
I poured about 1/3 bottle when the motor was still hot and the ticking persisted after restart and a short drive. Knowing that things 'reset' when the engine is cool I decided to reserve judgement until the next day. I took the car out today and after a good hour of driving and several engine restarts I still have a quiet motor!!! :D I will not declare this resolved just yet until I get a good week or two of silence but it's certainly looking promising!
Post by bertvorgon » 16 Jun 2016 14:16
Maybe you do not know..but...you can shim that pump. behind that BIG nut head is the blow off spring. If you put a very thin washer there, that will give you more oil pressure. Start THIN so as not to blow up the oil filter.... :lol:
