1969 bluebird coupe sr20 build
Re: 1969 bluebird coupe sr20 build
195/50/15 hahaha do you think I need a camber adjustment? The rear cambers as you go lower ya?
Yes, but your problem is going to be that the rear toes out as you lower it, as well. That's what eats the inside edges of tires, not the camber. It's also what will spit you off the road.larooj42 wrote:The rear cambers as you go lower ya?
Ohhh I see what your saying the new brackets for the camber will it also fix the toe problem?
I'm saying thoose wheels will barely fit if you just cut the springs, or run coilovers .... .. but if you modify the rear for adjustable camber,, then the wheels will no longer just barely fitlarooj42 wrote:195/50/15 hahaha do you think I need a camber adjustment? The rear cambers as you go lower ya?
isn't it 15x8.5 -6 or -10??? ....... mini-flares are needed for 15x9 -10's .... and streched tires... .. I'll buy them if you want adjustable camber/toe brackets (alot safer for SR20DET's or any lowered 510) .... maybe you don't want to lower it enough to need fixed camber?
Yes, (depending on which brackets you're using) but once you "fix" the camber, see Indy's post above... Reducing camber brings the top of the tire out, not the bottom of the tire in.larooj42 wrote:Ohhh I see what your saying the new brackets for the camber will it also fix the toe problem?
No its a -8 but wait so your saying that if I fp the brackets it won't fit? You'll buy them?indy510 wrote:I'm saying thoose wheels will barely fit if you just cut the springs, or run coilovers .... .. but if you modify the rear for adjustable camber,, then the wheels will no longer just barely fitlarooj42 wrote:195/50/15 hahaha do you think I need a camber adjustment? The rear cambers as you go lower ya?
No,,, If you ever want to sell that pair of Longchamps,, let me know .... I want them ....larooj42 wrote:No its a -8 but wait so your saying that if I fp the brackets it won't fit? You'll buy them?
This is a 15x9 -10 on a "stock" rear crossmember/non-fixed camber/toe: ... and very pulled/rolled fenders:
Holy titties that's a sick 510!!!! I won't sell em sorry lol
I like the addition of the grill in the opening between the front park/signal lights. Looks good.
Chad
Chad
Is anyone willing to buy my bluebird sss tail lights off me?
Someone might. Post up a Classified ad with pictures.
- Datsun 1600 Nut
Nice longchamps dude!
If you are selling the Coupe tail lights, what are you putting on the car?
"When you feel like giving up, remember why you held on for so long in the first place..."
Current Car's:
1971 P510 1600 SSS Coupe
1972 P510 1600 SSS
1972 P510 1600 SSS
1973 P510 1600 SSS
1973 620 Pickup
1979 PA10 1600J
1980 280ZX
Current Car's:
1972 P510 1600 SSS
1972 P510 1600 SSS
1973 P510 1600 SSS
1973 620 Pickup
1979 PA10 1600J
1980 280ZX
