GAS 1600
Garvice
Re: GAS 1600
Post by Garvice » 30 Jul 2017 06:53
Spent a couple of hours tonight fixing all the photo bucket dead images. Gave me a chance to reminisce along the way. Original goal of this car was to build a cheap car quickly, however the car required far more work than I thought and I definitely chose the hard way with most decisions. Some of the things I underestimated:
- Wasn't expecting so little steel and so much bog/rust
- Didn't expect to replace both floors/tunnel to do an engine swap
- Didn't think I'd need to build a new radiator support to offset the radiator
- Hadn't expected crash damage
- Completely forgot how anal I could be
Well my eldest who was 2 when I got this car turns 7 tomorrow so thought it fitting to remind myself of a few old naive posts.
22-09-12
Plans for this car are a quick (like to get it on the road late next year) and cheap build to give me something to enjoy while the Z sits in modification jail.
26-09-12
I'm not so sure about the "optimistic" quick and easy build statement.
Always fun nonetheless!
BP
This man had a Crystal ball!
03-02-13
Cheers mate, hope to have body work done by March/April.
Still doing body work, ha.
17-04-14
the original plan was a quick and cheap build that was going to be 12-18 months. Which if you go by my first post would put me at around October last year to March this year.
06-04-14
First engine start
Congrats bud. Downhill from here
16-05-15
Drove out of shed under own power.
Pretty much a black hole end of 2015 through early 2017 due to various other projects.
One thing I'd do differently, build in a bigger shed with another hoist as a car on your hoist for 5+ years is not cool. Ha.
Re: GAS 1600
Post by Three B's Racing » 31 Jul 2017 05:41
[quote="Well my eldest who was 2 when I got this car turns 7 tomorrow so thought it fitting to remind myself of a few old naive posts.
[/quote]
That's cool, my eldest was 8 when I got started on my 510. She's 32 now :shock: and on occasion metions she did the sanding on the rear light panel prepping for paint, and she you such a good job sweety DOH!! Wrong sentence for an ex MP Sergent 8>o
Garvice
Re: GAS 1600
Post by Garvice » 31 Jul 2017 14:08
Ha, yep can imagine you might end up in the fetal position on the floor, ha.
Garvice
Re: GAS 1600
Post by Garvice » 05 Aug 2017 07:21
Another 3 items off the list and I think i am finished with all the rust repairs on the main body, only rust on doors to go.
Had a boot channel to fix, wasn't real happy with how this turned out as I couldn't get the mig in far enough to get a nice weld and then since the weld was a bit large couldn't grind it out nicely due to the lack of space to get a grinder in. But, it will do, must avoid rework.
ImageGAS1600_065_01 by Garvice, on Flickr
ImageGAS1600_065_02 by Garvice, on Flickr
ImageGAS1600_065_03 by Garvice, on Flickr
ImageGAS1600_065_04 by Garvice, on Flickr
ImageGAS1600_065_05 by Garvice, on Flickr
Minor holes behind the rear light.
ImageGAS1600_065_06 by Garvice, on Flickr
ImageGAS1600_065_07 by Garvice, on Flickr
Rust hole above rear driver's side door
ImageGAS1600_065_08 by Garvice, on Flickr
ImageGAS1600_065_09 by Garvice, on Flickr
Rear valence around exhaust. Need to get a smaller sander so i can file the weld. Also need to cut and weld a turndown on the exhaust outlet.
ImageGAS1600_065_10 by Garvice, on Flickr
And I fixed a dint in the rear quarter. Just realised while doing this post that you can't really see the fix in the photos. But it used to be a dint, now it's smooth.
ImageGAS1600_065_11 by Garvice, on Flickr
ImageGAS1600_065_12 by Garvice, on Flickr
To keep me honest/motivated, here is the job list. Decided to cull the jobs that are now done from the list rather than underline.
Wiring
  • Headlight Wiring
    Turn Signals
    Brackets for Engine bay wiring
    Fuel Pump/Sensor
    Rear Lights/Demister
    Radiator Temp Switch
Rust Repairs/Metal Work/Fabrication
  • Drivers Door
    Passenger Door
    Dashboard strip down/fabrication
    Steering Column Mount
    Exhaust outlet
    Brake line mounts radiator support
    Heater Install
    Air intake/filter
Purchase
  • Heat shielding
    Windscreen seal
    Rear Window seal
    Door Seals
    Window Seals
    Boot Seal
    Bonnet Seal
    Seat belts
Garvice
Re: GAS 1600
Post by Garvice » 25 Nov 2017 05:10
Started on the dashboard, but taking longer than i expected.
Using foamex board for the majority of the shape as it was free, easy to work with and will give that new car smell as it degrades over time.
The top section will be wrapped in a thin foam and black vinyl, the gauge surround will be painted black and have a thin acrylic sheet over it.
Still haven't decided what I will stick in the empty space to the right of the gauges or how i'll fix up the glovebox section.
The centre console part i started with some 2mm thick aluminium sheet but it was affected by the heat of the grinder too much, so stepped it up to 8mm aluminium and milled it out. Will probably paint it black and have a few countersunk screws through the front of it to hold it in place. Lost a bunch of photos, so don't have one showing the mount of the air vents, but they attach to that same bracket that holds the radio and controls.
On with the photos.
ImageGAS1600_066_01 by Garvice, on Flickr
ImageGAS1600_066_02 by Garvice, on Flickr
ImageGAS1600_066_03 by Garvice, on Flickr
ImageGAS1600_066_04 by Garvice, on Flickr
ImageGAS1600_066_05 by Garvice, on Flickr
ImageGAS1600_066_06 by Garvice, on Flickr
ImageGAS1600_066_07 by Garvice, on Flickr
ImageGAS1600_066_08 by Garvice, on Flickr
ImageGAS1600_066_09 by Garvice, on Flickr
Re: GAS 1600
Post by two_68_510s » 25 Nov 2017 11:04
Freaking cool! Nice to have a mill!
greenthumb
Re: GAS 1600
Post by greenthumb » 25 Nov 2017 12:58
That's amazing work. Looks fantastic! Keep the updates coming
Garvice
Re: GAS 1600
Post by Garvice » 25 Nov 2017 16:53
Thanks guys. Mill definitely comes in handy, just need a lathe now for when I need to make round stuff.
Re: GAS 1600
Post by Byron510 » 28 Nov 2017 05:56
Just reread this whole page - interesting how projects go from simple beginnings to...well to this! That must have been fun wrapping up your whole thread over a 5 year period.
Great work on a custom dash,few step into custom territory on dashboards.
Way to stick with it, and for keeping us updated.
