GAS 1600
Re: GAS 1600
Did the drivers side inner rear quarter panel today.
Started with this after removing the wheel arch section and the top brace.
GAS1600_018_01 by Garvice, on Flickr
First section.
GAS1600_018_02 by Garvice, on Flickr
GAS1600_018_03 by Garvice, on Flickr
GAS1600_018_04 by Garvice, on Flickr
Wheel arch section
GAS1600_018_05 by Garvice, on Flickr
Rear section, I didn't spend too much trying to make this look pretty as you can't see it and this car needs to be on the road this year.
GAS1600_018_06 by Garvice, on Flickr
Top Brace
GAS1600_018_07 by Garvice, on Flickr
Few finished pictures
GAS1600_018_08 by Garvice, on Flickr
GAS1600_018_09 by Garvice, on Flickr
First section.
Wheel arch section
Top Brace
Re: GAS 1600
Made some quick changes to the inner wheel arch, had to remake and reweld in a section as it wasn't quite meeting the outer panel.
GAS1600_019_01 by Garvice, on Flickr
GAS1600_019_02 by Garvice, on Flickr
Cleaned up the cut on the quarter panel.
GAS1600_019_03 by Garvice, on Flickr
Matching the panels.
GAS1600_019_04 by Garvice, on Flickr
Spot welded (planished as I went)
GAS1600_019_05 by Garvice, on Flickr
Stitch welded (kept planishing as I went)
GAS1600_019_06 by Garvice, on Flickr
GAS1600_019_07 by Garvice, on Flickr
Ground and a bit more planishing. Might have planished a little too much on the weld before grinding as the weld was pushed into the panel a little.
GAS1600_019_08 by Garvice, on Flickr
GAS1600_019_09 by Garvice, on Flickr
GAS1600_019_10 by Garvice, on Flickr
GAS1600_019_11 by Garvice, on Flickr
Bit of primer on
GAS1600_019_12 by Garvice, on Flickr
GAS1600_019_13 by Garvice, on Flickr
GAS1600_019_14 by Garvice, on Flickr
GAS1600_019_15 by Garvice, on Flickr
GAS1600_019_16 by Garvice, on Flickr
Will need to do a little work on the wheel arch.
Bit of primer on
- miguel sss
Re: GAS 1600
Your work is amazing!!!
Re: GAS 1600
Thanks Miguel. While I am happy with the level of panels that I have been able to create, every time I look at them I see something else I don't like. But, seeing as I am building this car as a quick build, I am doing my best to not go back and redo the panels too much. I will just use a bit of filler to make the panels straighter.Your work is amazing!!!
Re: GAS 1600
I have been pretty slack with updating this thread so this will be in two parts. This post is from 4/5 May.
GAS1600_020_01 by Garvice, on Flickr
GAS1600_020_02 by Garvice, on Flickr
GAS1600_020_03 by Garvice, on Flickr
It worked fantastic to keep all the dust in and away from the rest of the shed. I do have to come up with a different sandblaster if I do it again though, I was using the suction gun from my cupboard but it just uses far too much air.
GAS1600_020_06 by Garvice, on Flickr
GAS1600_020_08 by Garvice, on Flickr
GAS1600_020_09 by Garvice, on Flickr
Found some areas that need attention
GAS1600_020_04 by Garvice, on Flickr
GAS1600_020_05 by Garvice, on Flickr
GAS1600_020_06_zps4871190e by Garvice, on Flickr
GAS1600_020_07_zps6e418d58 by Garvice, on Flickr
GAS1600_020_10 by Garvice, on Flickr
Re: GAS 1600
This post is from today.
The car had been hit in the drivers front corner and the previous repair was rather dodgy. So I started with a fair bit of panel beating before unpicking the front end and starting over. I didn't get many good photos of the damage, but it was wrinkled a bit.
GAS1600_021_01 by Garvice, on Flickr
I started by cutting off the top outside support so that I could beat the panel back into shape a bit.
GAS1600_021_02 by Garvice, on Flickr
Support needed a bit of work too.
GAS1600_021_03 by Garvice, on Flickr
GAS1600_021_04 by Garvice, on Flickr
Then after some panel beating I unpicked the front end.
GAS1600_021_05 by Garvice, on Flickr
Started with a rough shape and went from there.
GAS1600_021_06 by Garvice, on Flickr
Added some detail (you will notice the detail is a bit crooked, I fixed that later on).
GAS1600_021_07 by Garvice, on Flickr
GAS1600_021_08 by Garvice, on Flickr
Decided the support need to be unpicked and rebuilt too. Look how many spot welds they used in the factory! Or maybe that was from the repair, either way, someone didn't want this to come apart.
GAS1600_021_09 by Garvice, on Flickr
GAS1600_021_10 by Garvice, on Flickr
Bit more detail.
GAS1600_021_11 by Garvice, on Flickr
Underneath the upper support needed some help so I got out my metal filler (mig welder) and went to town.
GAS1600_021_12 by Garvice, on Flickr
Bit better looking.
GAS1600_021_13 by Garvice, on Flickr
Made a new support.
GAS1600_021_14 by Garvice, on Flickr
GAS1600_021_15 by Garvice, on Flickr
GAS1600_021_16 by Garvice, on Flickr
Support in and a quick prime before welding the new panel in.
GAS1600_021_17 by Garvice, on Flickr
Panel welded in.
GAS1600_021_18 by Garvice, on Flickr
Needed to make a patch for the bottom.
GAS1600_021_19 by Garvice, on Flickr
And welds ground down.
GAS1600_021_20 by Garvice, on Flickr
I purposely left the radiator opening unfinished as I don't know the size of the radiator I will be using yet. I took lots of photos of the process, so hopefully I have enough to do a right up of how I did the panel in the metal forming thread.
Bit more detail.
Bit better looking.
Made a new support.
Panel welded in.
- two_68_510s
Re: GAS 1600
Sweet work man!
Re: GAS 1600
Your dedication to the sheet metal repairs continue to amaze me; nice work. And thanks again for posting the process as you go.
Re: GAS 1600
Thanks Joel.
Thanks Byron and no worries mate. Happy to post.
Re: GAS 1600
Not much of an update, only spent a little time out there.
Started seam welding
GAS1600_022_01 by Garvice, on Flickr
GAS1600_022_02 by Garvice, on Flickr
GAS1600_022_03 by Garvice, on Flickr
More rust repairs
GAS1600_022_04 by Garvice, on Flickr
GAS1600_022_05 by Garvice, on Flickr
Had to make a new flange as the old one was rusted off
GAS1600_022_06 by Garvice, on Flickr
More rust repairs
Re: GAS 1600
Finished the flange off.
GAS1600_023_01 by Garvice, on Flickr
Had a few holes to fill. First one I fixed by removing a section of the top support.
GAS1600_023_02 by Garvice, on Flickr
GAS1600_023_03 by Garvice, on Flickr
GAS1600_023_05 by Garvice, on Flickr
GAS1600_023_08 by Garvice, on Flickr
Others I fixed from the back.
GAS1600_023_04 by Garvice, on Flickr
GAS1600_023_06 by Garvice, on Flickr
GAS1600_023_07 by Garvice, on Flickr
Bought some guards and a bonnet off a local forum member. This was the first real purchase for the car.
GAS1600_023_09 by Garvice, on Flickr
GAS1600_023_10 by Garvice, on Flickr
Guards need some work at the bottom and the left one needs a little panel beating. Also need to panel beat the car a bit to get the gaps better. But much better then what I had.
GAS1600_023_11 by Garvice, on Flickr
Previous guards.
GAS1600_023_12 by Garvice, on Flickr
Previous guards.
Re: GAS 1600
Small patch, decided I didn't need the second wiper hole, especially since the factory design with steel blanking sheet is what made it rust..
GAS1600_024_01 by Garvice, on Flickr
GAS1600_024_02 by Garvice, on Flickr
GAS1600_024_03 by Garvice, on Flickr
Almost finished the engine bay, just need to fill a few more rust holes.
Re: GAS 1600
Minor update.
Well I think I have finished the engine bay now (other then front valence).
Filled a few holes.
GAS1600_025_01 by Garvice, on Flickr
GAS1600_025_02 by Garvice, on Flickr
GAS1600_025_03 by Garvice, on Flickr
GAS1600_025_04 by Garvice, on Flickr
Also filled a few holes on the sides but didn't take photos. They looked like holes, now they look like flat steel. Got the picture?
In regards to working on the sheet metal, sometimes I am my own worst enemy.
This is what I had done last week with the front driver's radiator support.
GAS1600_025_05 by Garvice, on Flickr
It needed a little piece at the front which I had cut off. Instead I decided to replace the hole section. HA.
Removed
GAS1600_025_06 by Garvice, on Flickr
New section made
GAS1600_025_07 by Garvice, on Flickr
Welded
GAS1600_025_08 by Garvice, on Flickr
GAS1600_025_09 by Garvice, on Flickr
Stupidly I forgot to paint the underside. Might have to seam seal it or something.
Filled a few holes.
Removed
New section made
Welded
Re: GAS 1600
Welded in the rear passenger bottom quarter panel that I had bought. This represents the last large rust repair panel on the body section of the car. Few small sections to touch up and the removable panels to work on, but for the actual body, this is pretty much it.
Camera broke so was using phone to take photos, consequentially I didn't take any photos of the work completed on the inside panel.
Started with this
GAS1600_026_01 by Garvice, on Flickr
GAS1600_026_02 by Garvice, on Flickr
Panel welded in
GAS1600_026_03 by Garvice, on Flickr
GAS1600_026_04 by Garvice, on Flickr
GAS1600_026_05 by Garvice, on Flickr
New section made for the rear panel.
GAS1600_026_06 by Garvice, on Flickr
New arch section made
GAS1600_026_07 by Garvice, on Flickr
Started with this
Panel welded in
- two_68_510s
Re: GAS 1600
Great progress, very cool to see it coming back to life.
