S15DET wrote:Interesting about that brace in the square tube.
Should be the blind nuts for the sway bar bolts.
OP, what exactly are you intending to brace/replace with the 4" tubes?
2x2" square tubing is "almost" the same size as the stock frame rail in the front .... but square tubing doesn't work well with the "folded seam" built 510
none of the metal is thick enough to call structural. ... . so you woulld need to make the ends of your frame rails strong enough with plates and boxed in areas,, but by then you might as well "re-build" exactly what was there stock (because that's one of the more structural pieces on a 510)
use 2x2" tubing .... . I think that's what the guy used in the above pics or 1-1/2" x 2"..... my "frame" rails are 2x2" 0.065 16 gauge (really thin/light/weak) ..
If you can get a recommendation for a local, hobbyist-friendly steel shop, that will help you now and in the future. A lot of steel stores operate for industry - big orders faxed in with purchase numbers. A little guy walks in and need 6' of 2x2 box...that's great, come back Friday.
A hobbyist-oriented steel store will also do industrial supply, but you can walk in, browse their selection, request the size and length of material you need and they'll cut it for you then and there. Sometimes there's a cutting fee, sometimes there isn't, but IME when there is it is something like 2.5-5% of the total. Planning ahead can get them to cut stuff for you at lengths that work for you, but they're still much happier cutting the least possible.
You can wander into your local steel stores and get a quick idea what they're geared toward, but a recommendation will make it quicker.
I found a local "small" steel shop that has an organized scrap section and they let me browse and pick what I need and since its scrap, there's no cut fee. I also had a friend today just give me 3 sticks of 2" square tube. It looks pretty thick and I'm thinking it could be overkill.
Yeah, .120 wall is a bit much. But sometimes free is good.
okayfine wrote:Yeah, .120 wall is a bit much. But sometimes free is good.
Sometimes....key word. That car could use all the rigidity it can get. I like how you are approaching this so far. Curious to see where it ends up......
.120" to .03" just means the 22ga he welds it to will fail first.
But I'm with you, nothing to lose.
Thanks guys I'm going to move forward with the .120 for this.
I've also found a 510 shell that has the front end smashed that a guy wants to sell me. I'm thinking about checking it out to see if I might be able to cut out some pieces for my rusty non-crashed shell. Unfortunately he wants $450 for it! I wont buy it unless I can get it for $100.
If it includes more parts (interior stuff, trim, lights, suspension) $450 may not be all that far off. If it's just a bare shell, I dunno, whatever it's worth as scrap.
