Bert Vorgon's Spring Maintenance Project
Re: Bert Vorgon's Spring Maintenance Project
Post by bertvorgon » 28 Mar 2013 16:25
MORE....IF YOU LOOK CLOSELY, YOU CAN SEE THE IMPACT DIMPLES FROM THE FORCE USED TO DRIVE THE STAPLE THROUGH.
REMOVING STAPLE FROM MY TRIM
IMGP5101 (Medium).JPG (69.02 KiB) Viewed 1536 times
IMGP5102 (Medium).JPG (145.72 KiB) Viewed 1536 times
MY TRIM APART, STEEL BACKING
IMGP5103 (Medium).JPG (161.35 KiB) Viewed 1536 times
Post by bertvorgon » 28 Mar 2013 16:29
MORE...
You can see that the holes in the rubber, are NOT the same as my trim...NO PROBLEM...easier to drill through rubber than try to re-drill the steel trim bits
DONOR STRIP AND MY TRIM
IMGP5104 (Medium).JPG (163.82 KiB) Viewed 1535 times
CLIPS TO START ALIGNMENT PROCESS
IMGP5105 (Medium).JPG (193.77 KiB) Viewed 1535 times
ALL CLEANED
IMGP5106 (Medium).JPG (170.7 KiB) Viewed 1535 times
Post by bertvorgon » 28 Mar 2013 16:37
more..
rubber lined up to the highest point it should be
IMGP5107 (Medium).JPG (183.84 KiB) Viewed 1534 times
alignment
IMGP5108 (Medium).JPG (202.06 KiB) Viewed 1534 times
pins indexing the new rubber through my existing holes
IMGP5109 (Medium).JPG (239.64 KiB) Viewed 1534 times
Post by bertvorgon » 28 Mar 2013 16:43
more....
The staple test was to both check the strength of the staple, and just to make sure I had enough grip....which they did. Overlap does not happen once it goes through all 3 levels.
PINS USED TO INDEX THROUGH THE RUBBER, TO PREPARE FOR RE-DRILLING HOLES LARGER
IMGP5110 (Medium).JPG (173.01 KiB) Viewed 1532 times
IMGP5120 (Medium).JPG (181.73 KiB) Viewed 1532 times
BOSTICH STAPLE TEST, TO CHECK CLEARANCES
IMGP5121 (Medium).JPG (216.97 KiB) Viewed 1532 times
Post by bertvorgon » 28 Mar 2013 16:49
more....
INDEX PINS REMOVED, READY FOR DRILLING.
IMGP5124 (Medium).JPG (84.3 KiB) Viewed 1532 times
GRIP RIGHT IN THE MIDDLE OF THE STAPLE HOLES
IMGP5125 (Medium).JPG (112.33 KiB) Viewed 1532 times
NEEDLE NOSE VICE GRIPS WORK GREAT TO BOTH KEEP THINGS FROM MOVING, AND LETS YOU HOLD ON WITH ONE HAND DRILL, 5/64"
IMGP5126 (Medium).JPG (110.29 KiB) Viewed 1532 times
Post by bertvorgon » 28 Mar 2013 16:53
MORE...
HOLES DRILLED
IMGP5127 (Medium).JPG (93.95 KiB) Viewed 1532 times
HOLES DE-BURRED
IMGP5129 (Medium).JPG (89.73 KiB) Viewed 1532 times
GOOD OLD BOSTICH STAPLES
IMGP5131 (Medium).JPG (128.25 KiB) Viewed 1532 times
Post by bertvorgon » 28 Mar 2013 16:56
MORE...
STAPLE INSERTED
IMGP5130 (Medium).JPG (84.3 KiB) Viewed 1532 times
STAPLE BENT OVER, READY TO BE SQUEEZED TIGHT
IMGP5132 (Medium).JPG (88.14 KiB) Viewed 1532 times
FINISHED NEW STAPLE
IMGP5128 (Medium).JPG (92.49 KiB) Viewed 1532 times
Post by bertvorgon » 28 Mar 2013 16:58
MORE...AND THAT IS IT!
so, this is the shape of the rubber to look for, does not even need the slight curve in my opinion.
Hope this helps someone else to refurbish a tired rubber trim set. Any questions, just ask.
Oh, I also settled on a HONDA (Stanley) bulb for the rear turn signals, and the front turn/running. After all my research, Honda does spec a true 43watt/3 watt bulb front and 43 watt rear, as long as they come in a Honda box. Stock was like 32/3 in the old 1073/1156/1157 configurations. Much difference...maybe a hair, but, at least all bulbs are new now, not blackened, etc.. and, they are not the cheap Chinese knock offs either, which almost all the manufactures supply now.
Even put a new festoon bulb in the dome light..really lived it up.
Now...on to the good stuff...TIRES!!!!!!! :twisted:
rubber shape to look for.
IMGP5123 (Medium).JPG (71.44 KiB) Viewed 1531 times
proflex
Post by proflex » 28 Mar 2013 21:08
Thanks for posting all the pictures on how you worked your way through the replacement of the rubber trim. I like the way you reassembled it using the staples, just like the factory did. My driver’s door rubber trim needs to be refreshed also so hopefully a good source for the rubber can be found by someone.
Post by bertvorgon » 04 Mar 2017 08:37
After getting the mini bike out of the way it is now time for the 510. I have promised myself ONE project at a time this year.
First was to unbolt the rear caliper and take the rotor off, so I could sand it with #80 grit, ready for new pads. That also let me check the caliper bracket mounting bolts for tightness. I will then check all bolts under the rear of the car and install a new fuel filter.
Next will be to pull front hubs and take to Specialty, where I will put new rotors on and check bearings. The pads in the car now have been in there for 20 years, have a bit of a glaze on them and there is a weird spot on the rotor. They sure do not owe me anything. I think the front pads were the last of the PERFORMANCE FRICTION's Super Pads. I went for the softest type of pad for that "race" caliper configuration for the Knox Mountain hillclimb and then street duty. Pad choice is always hard as no one pad does all that is required sometimes on our cars.I have gone with the BRAKEMAN's recommendation for both front and rear, so I will give a good assessment once broken in.
A good brake bleed will be the final task, I use the Wilwood 570 for street use.
I'm still agonizing over ordering my headlight upgrade, as our dollar is falling, so the exchange is quite brutal right now. That being said, I am planning on doing some good drives this season and there will be many starting and finishing in the dark.
The rust on there is due to parking the car after that last drive, where we hit rain. Just points out why I hate rain. There was no way I could get the car dry before the end of the season park.
IMGP1953 (Large).JPG (354.42 KiB) Viewed 987 times
IMGP1952 (Large).JPG (356.43 KiB) Viewed 987 times
Post by 510rob » 04 Mar 2017 09:47
headlight upgrade?
TheHeretic
Post by TheHeretic » 04 Mar 2017 15:23
Just noticed the outer trip/window squeegee guide here. Looks great! Just wanted to know if you used a staple gun or simply put each staple through and tightened it down by bending the tabs down. Did you use any adhesive at all? Thanks...
Carpe Diem!
Ryan
Post by bertvorgon » 04 Mar 2017 15:25
I just pushed the staples through, then I very carefully just bent the staples down, with a bit of a final squeeze..JUST. No adhesive at all.
So far, after 3 years, all is good.
Post by funwithmonkeys » 04 Mar 2017 16:04
wow 20 years on a set of pads, they definitely don't owe you anything. were they the same rotors for all that time? I will be interested to hear how much of a difference you notice with the new ones. I expect to get 4-5 years out of the rotors on mine judging by the wear on them after a year. The pads will probably be good for a while after that. With these wilwood pads I do have the benefit of making a dust screen behind me every time I am hard on the breaks and there is a light show at night.
Post by bertvorgon » 04 Mar 2017 16:32
Brakes only SLOW you down...so why use them?
One set of front rotors, mostly after our track day years, as that was a lot of road racing we did.
I hope these pads are not dusty like some have used, as they end up ruining wheels. Both Byron and James found that out. Are you using those Polymatrix that Andy like to use?
When you think of our drives now, I hardly ever use my brakes, specially from high speed, we tend to just carry our speed through the corners, at the limit, and as no one is trying to pass you going into the braking point, there is no need to be King of the Late Braker.
