1969 build
Re: 1969 build
Finally got my collection of nos lights for the car..would like to trade the front euro ones for US versions.anybody? The rear round marker lights are from a 69 roadster ones but identical to the 510 versions except for the rubber gasket.
- nos lights.jpg (154.58 KiB) Viewed 5197 times
Re: 1969 build
picked up the 5 lug conversion with 930 porsche cv.
- mw.jpg (123.3 KiB) Viewed 5192 times
Re: 1969 build
Diving right into this build, huh? thats a lot of sheet metal holders on the tunnel. Spot welding each hole?
'69 2dr KA24DET
Re: 1969 build
yes sirrrrr had the car for 2 months now...got to stretch the factory tunnel out to fit the wider TSR tunnel.
Re: 1969 build
i thought you picked it up recently since the first post was dated today i was think holy s#$% this guy works fast! what is you planned powerplant?
'69 2dr KA24DET
Re: 1969 build
How about some more pictures of that TSR crossmember, just love seeing Mario's work.
Re: 1969 build
Here ya go
1969 cross member all boxed in....water tight!
- tsr crossmember plated.jpg (84.8 KiB) Viewed 5144 times
Re: 1969 build
s15 sr20detfinn wrote:i thought you picked it up recently since the first post was dated today i was think holy s#$% this guy works fast! what is you planned powerplant?
Re: 1969 build
powder coating polishing,painting all done
- grill.jpg (151.68 KiB) Viewed 5139 times
Re: 1969 build
No expense spares on this build. Going to swap a rack and pinion while your at it?
'69 2dr KA24DET
Re: 1969 build
probably will do rack and pinion.
Re: 1969 build
Big thanks to Member Bike Papa for putting his 510 project on hold to fab me up a drivers floor pan and drivers rocker. You can really see from the pictures that he has great attention to detail and make sure his stuff fits EXACT as it should.
- bp rocker.jpg (100.72 KiB) Viewed 5055 times
- bp floor.jpg (74.42 KiB) Viewed 5055 times
Re: 1969 build
Drivers floor pan installed today...will send car to media blasting,SEM seal all seams,then tow it to Linex bed coatings on a rotisserie to have inside of car sprayed and underneath.
- installed floor pan.jpg (127.06 KiB) Viewed 5055 times
Re: 1969 build
it was important to match the curvature of the factory rocker as well as the reverse tapers of the two horizontal sections.
This was not a difficult piece to make. it just required some careful measuring.
it also helps to work for a sheet metal shop!
BP
BP
- rocker pdf.jpg (105.1 KiB) Viewed 5027 times
1971 Datsun 510 2 door
08 VW R32
69 BSA 650 Firebird Scrambler
Too Many Bicycles
08 VW R32
Too Many Bicycles
- PoorMtnKid
