68 Dime, My car for Highschool!
That4doorKiD
Postby That4doorKiD » 18 Aug 2015 21:48
So it was originally my brother's 510, but he never continued working on it, just died out for him, so here I come to make this my first car.
Doing this update bearly, and took me about 6-7 months so far.
68 4doorFanatic
That4doorKiD
Re: 68 Dime, My car for Highschool!
Postby That4doorKiD » 18 Aug 2015 21:56
Homemade spacer for a gas cable throttle on SU's
Tried to put on headers, but cracked two bolts in the head :oops: taking out the L-18 to put something else
68 4doorFanatic
Postby two_68_510s » 18 Aug 2015 21:57
Nice dash.
That4doorKiD
Postby That4doorKiD » 18 Aug 2015 22:01
My Dad helped me put in the motor and tranny.
5 speed Dogleg going in!
68 4doorFanatic
That4doorKiD
Postby That4doorKiD » 18 Aug 2015 22:08
Mazda B2200 truck fuel neck upgrade, from ratsun
Going to be my muffler with 30in. glasspack in front of it.
32/26 DGV
Upgraded to bigger steering knuckles becasueBALLJOINTS were 14mm
68 4doorFanatic
That4doorKiD
Postby That4doorKiD » 18 Aug 2015 22:16
So currently, I have little last things to do...
-Put on Carburetor
-Attach push linkage
-Weld up exhaust
-Find and attach 2.5in. hoses for gas tank neck upgrade
-Bleed Brakes, Clutch(new slave cyl btw)
-Seat Belts 2 point race harness
-DMV papers, Car insurance...
I need bre spook or MK1 Large Duckbill?
BTW This is how my dime used to sit a couple months ago, currently on jacks because of my current finishings/doing right now.
teasers...
68 4doorFanatic
That4doorKiD
Postby That4doorKiD » 18 Aug 2015 22:17
68 4doorFanatic
Postby Byron510 » 18 Aug 2015 22:24
Damn good start - nice car... and nice 68 dash!
Man I love 68’s.
Looks like it has good bones to start with, and you are keeping it relatively simple and strait forward. You'll enjoy it.
That muffler looks good, but you might find you'll have to hack and slash to make it fit - 510's are not very muffle friendly.
Welcome - heck of a photo introduction => keep it coming.
Ctrack
Postby Ctrack » 18 Aug 2015 22:57
Looks like an awesome project mate keep up the good work!
Postby okayfine » 19 Aug 2015 05:41
Wheels are awesome. Echoing Byron's comments about the muffler, it needs hacking or you're going to hang it low to clear. I run 4" round mufflers in the stock location and it fits easy, but once tried a 2.25" Dynomax Turbo and it wasn't fitting, and that was a single-outlet!
Did you calculate the resulting rear spring rate after cutting? What's your front spring rate? Generally you want the rears to be slightly stiffer, but have to account for the rear motion ratio since the spring is inboard of the wheel relative to the pivot at the crossmember.
Great progress!
That4doorKiD
Postby That4doorKiD » 19 Aug 2015 14:00
Byron510 wrote:Damn good start - nice car... and nice 68 dash!
Man I love 68’s.
Thanks!, I test fitted the muffler, gonna be tucked up pretty good in their. Just need to support it with hangers.
68 4doorFanatic
That4doorKiD
Postby That4doorKiD » 19 Aug 2015 14:02
okayfine wrote:Wheels are awesome. Echoing Byron's comments about the muffler, it needs hacking or you're going to hang it low to clear. I run 4" round mufflers in the stock location and it fits easy, but once tried a 2.25" Dynomax Turbo and it wasn't fitting, and that was a single-outlet!
Great progress!
I think the Ebaich springs are 250lbs in front And didn't calculate the rear, they were pre-cut springs.
68 4doorFanatic
Postby okayfine » 19 Aug 2015 15:37
I'd recommend determining the rear spring rate. Rate could be all over the map depending on what spring was used. If stock rear spring was cut, even that much, you're nowhere near 250in/lb wheel rate, so it'll probably understeer bad. If a Roadster Comp spring was cut, you might be north of that and have oversteer as an issue.
That4doorKiD
Postby That4doorKiD » 19 Aug 2015 21:26
Got my fuel neck upgrade done finally today! Just using these hoses as temporary till I can source out some better hose. Overall, upgrade looks good!
68 4doorFanatic
That4doorKiD
Postby That4doorKiD » 02 Oct 2015 16:21
Put it on trailer to get aligned and tranny made this nasty rubbing noise, from throw out bearing possibly. Any who, I don't know what to do about that :?: , besides buy a new one, but which bearing do I use? Also got to register my car finally.
I've been impatient lately because of this tranny problem and haven't worked on it for abou 2-3 weeks. :oops:
put correct ful grade on there finally too
I like the stock camber, how low the straps pull it down, about how low i wanna lower it more. and ofc i'll need camber lates in the front too.
68 4doorFanatic
Users browsing this forum: No registered users and 4 guests
