50 Shades of Grey....
Re: 50 Shades of Grey....
Post by Byron510 » 26 Sep 2016 09:12
Did you have any luck with the fender roller?
That's a pretty stiff part of the car to move. And you can't go too far as you'd be into the door recess area.
Tire makes also play a roll in fitment. For instance I have found that performance tires generally have a more square cross section than touring or all season tires. That being said, I ran Yoko's and Pirelli's in the day on those wheels...
Post by RMS » 26 Sep 2016 10:16
Byron was it a 68 or 69 car that the snow flakes cleared on ?
Grinder
Post by Grinder » 26 Sep 2016 10:36
Yeah its pretty good now. Can't remember what tires they are but they are cheap tires.
Post by Byron510 » 26 Sep 2016 10:56
RMS wrote:Byron was it a 68 or 69 car that the snow flakes cleared on ?
It was a wagon, actually. here's an old photo on a Duff Lake run rest in Lillooet.
Red Wagon Duffy 2.jpg (273.09 KiB) Viewed 953 times
Grinder
Post by Grinder » 29 Sep 2016 12:56
I'd like to do a KA swap but she'll end up being a garage queen. I've got engine mounts for the 620 for a KA24DE swap so she'll be on the hoist for a while. I bought a 720 with a Z22 as a spare for the 2dr turbo car so an LZ22 it is!
Doraemon
Post by Doraemon » 02 Oct 2016 11:17
Ouch sorry to hear about the crash :( But at least it looks great again !
Grinder
Post by Grinder » 06 Oct 2016 09:13
Car is pretty solid but the under carriage has surface rust over a significant portion. It's keeping me awake at nights so before it starts raining 24/7 it time to clean, treat and seal the under carriage.
Lets wrap this baby up and get filthy cleaning and prepping the under carriage.
Time to seal it up - KBS Coatings urethane paint - higher solids and better UV resistance than POR-15 at a lower cost. I've switched over.
Post by RMS » 06 Oct 2016 09:49
make sure you replace that brake line. the paint will bite deep and its high surface tension will cause cracks in the hose.
did you use any type of acid to neutralize the rust prior to painting ?
I'm fearful of rust paint with its often higher surface tension than adhesion witch in my mind creates perfect conditions for poultice corrosion.
Grinder
Post by Grinder » 06 Oct 2016 12:25
Brake lines have been replaces with a hot tip from Byron - pre made lengths from Lordco our local parts store.
Rust is neutralized with a zinc phosphate which is part of the KBS Coatings surface prep - Rust Blaster IIRC. They also have a degreaser.
I haven't completed the surface yet - urethane seam sealer and bed liner are the next step in the process.
Grinder
More progress with the Suzuki GSXR 750 ITBS running full sequential staged injection
http://youtu.be/j1KGoWcTehU
Post by RMS » 06 Oct 2016 14:30
good to hear about the phosphate. will you need to sand the rust paint or use a tie coat to adhere the bedliner ? I did the same thing with the pre made lordco lines on 6inches of rust.
Post by 510rob » 06 Oct 2016 14:45
Grinder wrote:More progress with the Suzuki GSXR 750 ITBS running full sequential staged injection
"This video is private."
Grinder
Post by Grinder » 06 Oct 2016 15:37
Oh I'll have to fix it when I get home - does this one work?
https://youtu.be/X0xwtvlvPzc
Grinder
Post by Grinder » 06 Oct 2016 15:40
RMS wrote:good to hear about the phosphate. will you need to sand the rust paint or use a tie coat to adhere the bedliner ? I did the same thing with the pre made lordco lines on 6inches of rust.
Yes you need to sand it down to get a good bite on it. Optimally using a urethane bed liner before the urethane paint kicks off would be the least amount of work but you can only tie up a friend's hoist for so long :) The dirty work is done now so it will probably be a winter on the floor under jack stands job once I bump the 260Z project out of the garage.
Post by 510rob » 07 Oct 2016 10:21
Grinder wrote:Oh I'll have to fix it when I get home - does this one work?
yes.
