Blue on Blue barn find 510
sahill510
Re: Blue on Blue barn find 510
Post by sahill510 »
As part of the brake system overhaul, I'm replacing the brake master cylinder with a rebuilt OEM 3/4" unit from my parts stash. The backing plate had a bit of rust, so I used this opportunity to try out Evapo-rust. 12 hours of soaking and not a trace of rust. Pretty sweet. (Can I soak the entire car :D )
Before
WP_20160816_18_50_28_Pro 1.jpg (153.71 KiB) Viewed 5618 times
After
Post by two_68_510s »
Great avatar Mr. Hill. That stuff works
clean71
Post by clean71 »
very cool find thumbs up
1971 PL510 4DOOR AUTO
1969 PL510 WAGON 4SPD
1969 PL510 2DR 4SPD
Doraemon
Post by Doraemon »
That looks great ! Did you by the way tried vinegar already for getting rust away ?
sahill510
Post by sahill510 »
I've only used vinegar on electrical components with surface rust. This rust was a lot more "crusty" so I decided to give this product a shot. I still need to figure out a good short term solution for the rust in other locations. (Like the trunk/rear fender seems) Might try yo clean up as much as I can in those locations and switch to a rust converter product like zero-rust.
sahill510
Post by sahill510 »
Progress is still slow. I finished installing a new brake master cylinder (glad I kept some of my stock parts) and new hard lines to the splitter. Started working on restoring the driver's rear brakes, but was unable to remove the old brake drum. Used lots of rust penetration fluid but unfortunately the threads on the bolt holes used to push the drums off stripped :( Gotta figure out another way of getting them off.
sahill510
Post by sahill510 »
Figured I'd post an update when I made more progress, but I've been sidelined working on getting Randy York's Orange KA24E (Single-cam) 510 buttoned up before putting it up for auction. The only real progress I've made on the blue barn find 510 was finally getting the title/licensing straightened out with the DMV.
After 3 trips to the DMV and several back and forth mailings of documents and additional fees (cuz this year's registration was due) I finally managed to receive the title in my name and new tags to use on the original blue California plates!
Before:
After:
Once Randy's 510 is out of the garage and off to its new home I'll start working on this car again. I've decided to pull the engine/tranny out of the car due to issues with the clutch and ongoing struggles with removing the front cover. Might as well do a tear down of the engine :D
sahill510
Post by sahill510 »
Another quick update. I've run into some issues with broken bolts on the front cover of the original motor. I tried removing the front cover, but the crank pulley won't budge. I'm going to take the original motor out and rebuilt it at a later time. In the mean time I went up and grabbed an L18SSS motor (with SUs and 5-speed) from a longtime 510 buddy in Ojai. (Which he just removed for his own KA swap)
I'm doing some minor clean up on the motor and will swap it in after Thanksgiving. Hoping to be able to take the car out on its own power before the end of the year.
Post by goichi1 »
Nice work! Do you know what car the new motor came from? was it a Silver Bluebird 1800SSS 4 door by chance??
sahill510
Post by sahill510 »
No, the motor came from a 2-door sedan.
sahill510
Post by sahill510 »
January of 2018 was spent removing the original L16 (put into storage for now) and rebuilding and repainting the front suspension due to the sad condition of all the components. (29 years of just sitting will do that to a car) I chose not to powdercoat any of the components at this time due to money restraights and not knowing exactly what the long-term plans are for this project. For now its being mostly refreshed as stock except for the L18SSS and 15/16" Datsun Motorsports front sway-bar.
Removal and refresh of stock suspension
NOS Idler arm, new center link and refreshed steering box and engine crossmember
Refreshed the L18SSS - New gaskets, cleaned up and repainted
Engine in and ready for accessories
Trial fitment of Koyorad radiator
iceman510
Post by iceman510 »
I am considering the Koyo radiator as well. Please give some comments on how it fits, etc.
Looks like it sits a bit high compared to stock, IIRC.
sahill510
Post by sahill510 »
The Koyo radiator fits great. I've installed the slightly cheaper "Champion" aluminum radiator on another 510 and the fitment wasn't as nice. I was also able to mount the stock fan shroud with no issues. So far I'm very impressed with it. They only caveat is that the ~$270 price doesn't include a radiator cap...
iceman510
Post by iceman510 »
Ha! Cheapskates.
Thanks for the info.
