Noob build
Tank510
Re: Noob build
Post by Tank510 »
It needs a good buffing and cut polish but overall I'm pretty happy with how it turned out.
Clear coat:
Heinrich
Re: Noob build
Post by Heinrich »
AWESOMENESSSSSS!!
Re: Noob build
Man, you are brave. Your first paint job, in a little shed, in BLACK! Man you have balls!
That’s got to feel good. I did my interior first, then did the outside.
Keep em coming
Tank510
Re: Noob build
Post by Tank510 »
Byron510 wrote:Man, you are brave. Your first paint job, in a little shed, in BLACK! Man you have balls!
Keep em coming
Thanks Byron, it's paint job 3 if that makes it any better... but there is no booth to rent over here so I had to make it work...
Short of the visible spots between the B and C pillar, the interior is getting lizard skin since it'll be covered with carpet anyway.
Tank510
Re: Noob build
Post by Tank510 »
Undercoated the trunk last night, the smell of this stuff is downright awful. Looks like I'll be wearing the respirator for another week while it cures...
Tank510
Re: Noob build
Post by Tank510 »
Lizard skin sound deadener on the inside, it sprays pretty nice and the ceramic heat insulation will follow tonight. The true test will come when it's driving around.
Tank510
Re: Noob build
Post by Tank510 »
Did some cleaning of the intake manifold, the inside was full of black crust from the EGR. Cleaned it all out, sandblasted and powder coated everything. Getting replacement hoses for a 240SX is proving more difficult than I had hoped, fingers crossed they have stock in the US.
iceD
Re: Noob build
Post by iceD »
Did you buy the spray kit for the Lizard skin or how did you install it looks great
ice D
Tank510
Re: Noob build
Post by Tank510 »
iceD wrote:Did you buy the spray kit for the Lizard skin or how did you install it looks great
ice D
I bought their spray kit, it's not identical to an undercoating gun but works the same way. I was tempted to spray it with a regular 20 dollar gun but decided to play it safe. It recommends a tip pressure of 55 PSI, after some trials going closer to 70 is what I found best. Hope that helps..
MikeY
Re: Noob build
Post by MikeY »
I'm in Qualicum and just about at the stage where I have to do something to the floors. Where did you buy the lizard skin and would you rent or sell the spray gun. Both seem a little expensive on Amazon. And how much did you use.
Thanks
Tank510
Re: Noob build
Post by Tank510 »
MikeY wrote:I'm in Qualicum and just about at the stage where I have to do something to the floors. Where did you buy the lizard skin and would you rent or sell the spray gun. Both seem a little expensive on Amazon. And how much did you use.
Thanks
I bought it all from Jegs and had it shipped to my mailbox in Sumas while still living on the mainland. There's a shop in Langley that sells it, can't remember the name. For a case of beer you can borrow the gun anytime, we'll just have to figure out a way to get it to and from Victoria.
iceD
Re: Noob build
Post by iceD »
They sell it at The Old Car Centre in Port Kells. I just spoke to them they will ship it for free. 604-888-4412. $185/gallon in a 2 gallon pail.
ice D
Tank510
Re: Noob build
Post by Tank510 »
Also, what you see there is a gallon for both sound deadener and heat protection. I had to go thinner to get two coats everywhere, so if you're doing the trunk then go for 2 gallons for each product you want to use.
iceD
Re: Noob build
Post by iceD »
What they have is in a 2 gallon pail why he gave me a per gallon price is a little odd 190$/gal for the heat product
ice D
MikeY
Re: Noob build
Post by MikeY »
Thanks for the info. I'm planning a trip to Vancouver in March so will try to pick some up. Its sound id like to get rid of. Im getting old is seems. And I have to drop off some parts to chrome at some point in Victoria. After I get some product I will try to arrange a Vic trip.
I just looked again on amazon.ca and $127 a gallon for either heat or sound lizard skin. Free delivery with prime. That looks like the way to go.
