Noob build
Heinrich
Re: Noob build
Post by Heinrich » 21 Nov 2017 21:33
Nicely done.
Tank510
Re: Noob build
Post by Tank510 » 22 Nov 2017 09:34
And undercoated. It's a bit more textured than I'd like but it will do.
Tank510
Re: Noob build
Post by Tank510 » 29 Nov 2017 08:17
"This thing is pretty much rust free" ... Famous last words. Well a few bubbles in front of the rear wheel arches have turned into another fun exercise. Glad this was found with the car still on the rotisserie, got the passenger side inner rocker done yesterday. POR-15'd the inside before welding on the new panel and I bought some Eastwood frame paint that I'll apply to hopefully be able to cover the heat affected areas. The major concern is the inner to outer rocker interface, I'll do some digging on what others have used to protect the area from corrosion.
The drivers side wasn't as bad, but still needs some love. Those three had areas had excessive pitting, the rest was in decent shape.
Fred_L-P
Re: Noob build
Post by Fred_L-P » 29 Nov 2017 08:39
What did you use for your undercoat?
Tank510
Re: Noob build
Post by Tank510 » 29 Nov 2017 08:51
Fred_L-P wrote:What did you use for your undercoat?
Pro Form Undercoat - sprayed it with an undercoating gun at 80PSI and roughly 75 ft. of air hose.
http://ca.proformproducts.com/en/produc ... undercoat/
Tank510
Re: Noob build
Post by Tank510 » 02 Dec 2017 10:43
And it is done, coated the inside of the joints with POR-15. It will be a challenge to touch it up in the weld areas... any recommendations?
Re: Noob build
Post by two_68_510s » 02 Dec 2017 11:05
Nice to see the rust on the floor where it belongs, good job.
Re: Noob build
Post by Three B's Racing » 04 Dec 2017 05:17
Welding will simply bubble the POR-15 and expose raw metal for a fresh coast of rust. I'd recommend going back in through the back side and adding a fresh coat in those areas.
Tank510
Re: Noob build
Post by Tank510 » 04 Dec 2017 09:46
Three B's Racing wrote:Welding will simply bubble the POR-15 and expose raw metal for a fresh coast of rust. I'd recommend going back in through the back side and adding a fresh coat in those areas.
For sure, it's the joints that are not accessible with the paint brush that I'm wondering about. The weld at the underside of the rail is the big one, short of pouring paint down the inside of the quarter panel is there a better way / product to rust proof the area after welding? I guess the factory had the panels pre-coated and only the spot weld areas would be somewhat affected depending on the coating used, but any amount of water in there would eat away at the coating and then finally cause the panels to rust out.
spriso
Re: Noob build
Post by spriso » 04 Dec 2017 10:41
Michael Spreadbury
Spriso Motorsports
www.spriso.com
Re: Noob build
Post by Three B's Racing » 05 Dec 2017 06:48
Sounds exactly like this stuff from Eastwood. It goes on like paint which allows it to seep into all those you want it to go places then dries to a self healing film.
Tank510
Re: Noob build
Post by Tank510 » 05 Dec 2017 14:10
Three B's Racing wrote:Sounds exactly like this stuff from Eastwood. It goes on like paint which allows it to seep into all those you want it to go places then dries to a self healing film.
spriso wrote:Look at a product like this:
https://www.kbs-coatings.com/Cavity-Coater.html
Thank you for the tips guys! I will definitely use something like that...
Tank510
Re: Noob build
Post by Tank510 » 15 Dec 2017 15:26
After lots thin coats of filler and sanding we have arrived here... ready to block sand the body to finally get it ready for sanding primer.
Re: Noob build
Post by RMS » 15 Dec 2017 19:03
with the stock paint still on the car I would seal it with epoxy primer before 2k primer. every spot of red has the potential to fuzz.
Tank510
Re: Noob build
Post by Tank510 » 03 Jan 2018 08:29
RMS wrote:with the stock paint still on the car I would seal it with epoxy primer before 2k primer. every spot of red has the potential to fuzz.
Will do, that's the next step.
