Page 6 of 8
Re: 68 2-Door Restomod
Posted: 22 Sep 2016 19:37
by KCMO_68
Posted: 22 Sep 2016 22:42
by Colbino
Nice. Very nice!
I feel ya on the cheap 510 comment. I bought mine with the same sort of though process and as soon as I changed/upgraded one part the entire restoration was on.
Posted: 23 Sep 2016 05:42
by KCMO_68
Colbino wrote:Nice. Very nice!
Thanks! Also I'm glad to know I'm not the only one who fell into the trap of having everything get cleaned and fixed as the build went on.
Posted: 23 Sep 2016 05:49
by KCMO_68
Posted: 30 Sep 2016 17:01
by McShagger510
Awesome Build! What's up with the white Skyline from the first page of pics??
Posted: 30 Sep 2016 18:45
by two_68_510s
Hey moderators, I would pick this as a Featured Project, if I had the power you hold!
Posted: 01 Oct 2016 08:15
by KCMO_68
two_68_510s wrote:Hey moderators, I would pick this as a Featured Project, if I had the power you hold!
Wow. Thanks for the praise! And from a 68 fan no less
Posted: 01 Oct 2016 08:29
by KCMO_68
Posted: 01 Oct 2016 19:10
by greenthumb
Very nice work on the plumbing! I'm loving the condensed version of the build. Feels like things are moving quickly, although it's unclear to me what the timespan actually was. Carry on!
Posted: 01 Oct 2016 19:48
by KCMO_68
greenthumb wrote:Very nice work on the plumbing! I'm loving the condensed version of the build. Feels like things are moving quickly, although it's unclear to me what the timespan actually was. Carry on!
I really wish that the actual build process only took the time that it's taken me to post the photos
This project so far has taken about 3.5 years. Probably going to be almost 4 years before it's actually complete and on the road. Once winter hits even if it's finished I'll probably hold off until spring to put it on the road. Avoid the salt as much as possible.
I'm really trying to self edit in posting things. I think I have over 1300 photos from the entire build process. But I figured that I should edit it down so that everyone gets the highlights and not a picture of every dent that was hammered out.
Posted: 01 Oct 2016 19:55
by KCMO_68
One of the things with going with a completely custom motor is that it creates some other differences that you don't really think about. Carpet is one of those things. The original owner had actually hacked up the transmission shifter hole quite a bit. He had made the hole about 2X larger than it ever should have been. So when the motor was put in, the extra space was welded back shut so that it looked as factory as possible. When we laid over a stock 510 carpet template it was obvious that it wouldn't quite work. So a template that would work for my car was made and sent off to the interior shop.
Posted: 01 Oct 2016 20:01
by KCMO_68
So earlier I shared photos of the custom header attached to the car. At that time the welding wasn't actually completely done. Just tacked together so that everything could be tested for fitment. Well before the engine could go back in the car (for the final time) the header would have to be finalized. I think the end product is pretty great and is probably one of my favorite parts of this build.
Posted: 03 Oct 2016 18:54
by McShagger510
That header is a work of art!
Posted: 03 Oct 2016 19:36
by RMS
how did you find working with the copper alloy brake lines ? I contemplated running the clutch line along the top like you (looks much cleaner) but I was concerned gravity bleeding would no longer work with the line above the reservoir? what style carpet did you chose loop/cut, nylon/ rayon? are you going to run underlay ? glue in or snap in ? I found ford model T has very similar rings and snaps if your going that route. I like snap in two piece carpet as the front is easily removed for auto X.
Posted: 04 Oct 2016 06:37
by KCMO_68
RMS wrote:how did you find working with the copper alloy brake lines ? I contemplated running the clutch line along the top like you (looks much cleaner) but I was concerned gravity bleeding would no longer work with the line above the reservoir? what style carpet did you chose loop/cut, nylon/ rayon? are you going to run underlay ? glue in or snap in ? I found ford model T has very similar rings and snaps if your going that route. I like snap in two piece carpet as the front is easily removed for auto X.
Does your local auto-x require the entire carpet to be out of the car? Locally here they just require no floor mats. I would presume that the carpet being left in would be fine, but now you have me wondering even for open track days. Didn't even think about this idea. Hmm...
