Fred's 73 2dr 510
Fred_L-P
Re: Fred's 73 2dr 510
Post by Fred_L-P » 27 Jan 2019 20:16
It's been a month and I'm still not done with the brake lines.......
I didn't spend much time working on the car, I work a lot lately and I got sick last week.
But I still can't believe how bad I am at estimating the amount of work & time required. From now on, I think I'll always triple my estimates.
Since I converted to rear disc brakes, I wanted to have a flex line to the calipers instead of the hard line from the drums.
I browsed the hoses on Rockauto and found the Nissan Leaf brake hoses (2017) should do the trick.
They're the perfect angle and long enough to go from the caliper, along the control arm and up to the floor to avoid having many fittings.
I removed the original brackets and made my own. Both sides are identical.
I ran the rear line inside along the transmission tunnel with a proportioning valve behind the seat for easy access.
I stopped for today because I'm not sure how I want to do the rest and I need to think about it.
Since I will not put the rear seat back in (because of the cage and fixed back seats), I think could run the hose through the floor where the white X is.
It looks like it's going to clear the CVs and be far enough from the exhaust while having plenty of play for the suspension travel.
From the inside I imagine it would look approximately like this. Would there by anything wrong with this?
Since I don't have much more to show, here's my dog keeping watch while I shovel the snow.
Fred_L-P
Post by Fred_L-P » 11 Feb 2019 19:34
I finally finished my brake lines. I went according to my previous plan.
So I drilled and poked my flex lines thru the rear floor.
Finished the line from the proportioning valve to the rear
I keep forgetting to put the fitting on the line before flaring...
And the finished rear lines that I restarted twice because I wasn't happy with the result.
It look's good to me for a first time.
Fred_L-P
Post by Fred_L-P » 11 Feb 2019 19:43
After finishing the brakes, I decided to do my In tank fuel pump conversion so I can finish the fuel lines routing.
I'll just copy/paste my post from the Powertrain thread because I'm lazy
I decided to go with the Tanks Inc PA-2 kit.
It's pretty straightforward and easy to do.
First, here's the tank. I have 2 tanks and I picked the one that looked like it's in the best shape from the outside.
Here's what it looks like inside...
From the filler neck
From the fuel sender hole
And the fuel sender. The second one is even worse.
Since I'll upgrade my cluster with Speedhut gauges, I decided to use a 9 inches Fuel Level Capacitance Universal Sender from them.
That being said, I settled on installing the pump in the center of the tank between the 2 baffles, as far back as possible.
Side note, I'm pretty sure there's enough room to install the Tanks Inc kit to the far left of the tank with the tray facing the right side to retain the original fuel level sender unit.
The top plate has to sit on a 6" flat surface.
I used a hole saw to drill the 4.5" hole.
I placed the tray/pump baffle inside the tank to check for fitment against the original tank's baffle.
The instructions says to put the tray sideways, so facing left or right.
As you can see, the tray is resting on the baffle and it is not centered on the hole.
I tried rotating it towards the back, but it was impossible to have it centered while sitting flat at the bottom of the tank.
The tank's baffle needed a notch for the tray to sit in the right spot. I managed to stuff my Dremel inside the tank with a flashlight to do the job.
Now, time to cut the pump bracket for the tank depth.
Measure twice, cut once.
Perfect fit, the plate is sitting flat on the top of the tank.
Now... remember I said to drill a 4.5" hole? Well... I used a 4" hole saw by mistake.
So I needed to cut 2 small notches to be able to drop the assembly inside the tank.
Assembly ready for test fit...
Everything looked good so I marked the fasteners locations with the assembly in place to make sure the pattern clocked properly.
Take your time while drilling, I had a couple of holes slightly off that needed rework to fit.
Done and back in the car so I can finish my fuel hoses/lines routing.
I wanted to clean and refinish the inside of my tank with the POR-15 Fuel Tank Repair Kit and finish the installation of the pump, but believe it or not it's too cold in the garage & in the basement to use the products... I'll have to wait till spring, maybe even summer.
Fred_L-P
Post by Fred_L-P » 12 Jun 2019 21:17
Damn I'm bad at taking pictures and keeping my build thread up to date...
I don't have much to show, but I'm still progressing. I can't even remember everything I did, so I'll go with the pictures I have in chronological order.
I probably mentionned it in previous posts, but I finaly cut out the rusted spare tire well. You can see it has already been patched by the POs. I don't have a picture, but the underside is just a big pile of bondo/filler. I stopped grinding the paint/bondo when I realized it looked more like a strainer than a spare tire well. I left a lip all around to weld a filler plate with a lap joint in place.
I finished cutting and mocking up the hoses for the fuel system.
This is the best place I found for the in line fuel filter.
I obviously needed an accelerator pedal and a longer throttle cable to work with the gtir ITBs.
So I bought an S13 pedal and throttle cable.
While removing the 510 pedal in the shell to compare it to the S13, I quickly realized it wasn't an original 510 accelerator pedal... Keep in mind It's my first 510 and I bought it in boxes... I don't know what the original pedal is suppose to look like...
It actually is a way better fit than the S13 pedal and works perfectly with the S13 throttle cable. So..... I have an S13 pedal for sale, anyone?
Does anyone know if there was a popular accelerator pedal swap back in the days? If anyone can Identify it, I'd greatly appreciate it.
S13 on the left / Unknown but perfect pedal on the right
And the throttle cables
Unknown cable that was in the car on top, short to reach an intake on the LH side / S13 on the bottom. I will need to be cut down 2 or 3 inches for a perfect fit, but It's also going to work as is.
Alright, so the next step is going to be metal work and rust repairs on the floors, engine bay and body.
I finished stripping the interior by removing the dash frame.
It's in pretty good shape, some surface rust but nothing major to fix. There are some cut outs in it because of the roll cage.
Surprise surprise... I found major rust in the lower windshield corners, behind the cage.I feel like this is going to be hard to reach with the cage in place.
Engine out. Hopefully the next time I drop it back in it's going to be in a nice, clean and freshly painted engine bay.
I'm still debating on making the radiator support removable or pulling/installing the engine & transmission assembly from under with Byron's method like many people suggested.
Last year I bought a couple of items from Datsport including the transmission cover plate for the Sr20 swap. It's now time to make it fit.
I started by widening the tunnel for the transmission plugs on either sides of the shifter with my highly specialized tooling.
I finished the job with a hammer from under the car. It's now wider than necessary, but I'm 100% sure the transmission won't hit the tunnel any more.
And the Datsport Shifter cover. The fitment was really good. I only needed to bend it a bit near the seat brackets to close the gap with the original tunnel. I'm still not sure how I'm going to fix it there. My 2 options were welding it in place or screw it in place to have an easy access to the shifter. I asked Baz from Datsport what he suggests. He suggests to stick it there with what he called "liquid nails for steel" and rivets. Let me know what you guys think.
Since that was a rally car, the underside really took a beating. Especially the frame rails under the front floors. I forgot to take a picture... Maybe in the next post. I ordered some 3" x 2" x .100" rectangular tubing to make new rails. I also have a 4x8 of sheetmetal for the other repairs. It's time to practice my welding skills!
One more problem I have to figure out.
As you can see with this cage, I can't use the stock hood hinges.
And I don't want to run 4 hood pins on my street car... Anyway it would never pass the inspection.
So I have to figure something out. I went to the scrap yard to grab a a couple of items earlier this spring, so I bought 2 different sets of more modern hinges that I might be able to do something with. We'll see.
I also took advantage of the spring sales to buy a Speedway motors universal harness and my custom SpeedHut Gauges. I got the 10k rpm gauge just in case I decide to build a high revving VE head in the future.
I probably forgot alot of small bits... but anyway that's what I got for today.
Like I said, the next big step is all the metal work and repairs before the paint.
On a side note, I went to the Spring Classic races at Circuit Mont-Tremblant. It is in my opinion one of the best (if not the best) and most beautiful race track in Canada. Of course I didn't take any pictures, but there was an awesome 1972 RX3 running in 12A in the Vintage category. We chatted for a bit, very nice guy. I managed to find his channel on youtube.
Here' one of his races where he started pole position against all the big V8s. He did hang up in there for a damn long time. Very impressive.
https://youtu.be/ks4fDUNI5cg
andrew.lori
Post by andrew.lori » 14 Jun 2019 07:31
Fred your car is looking great and your progress is in line with such a project keep pressing on you will get there. I know Russ Bond with the RX3 good guy and a wicked fast car. I'm heading to Mosport this weekend and he will be there at the front of his group as usual.
Andrew
1966 Sunbeam Tiger MK1A
1973 Toyota Celica
Post by two_68_510s » 14 Jun 2019 08:58
Hey Fred, nice stuff. Too bad about the extra rust.
What does it look like with the windshield out? Kind of a complicated corner in there.
Fred_L-P
Post by Fred_L-P » 14 Jun 2019 11:33
andrew.lori wrote:
14 Jun 2019 07:31
Andrew
Thanks Andrew, you're always welcome to come help if you wish :wink:
two_68_510s wrote:
14 Jun 2019 08:58
I haven't taken the windshield out yet. I'm afraid its going to be even worse under the rubber.
Fred_L-P
Post by Fred_L-P » 15 Jun 2019 09:07
My girlfriend randomly gave me my first Datsun related gift last night for our 13th birthday, which is only in two month but she couldn't wait.
