Page 4 of 4
Re: Five-Hundred and Ten
Posted: 04 Feb 2018 13:26
by MarkReidHRC
Kreid wrote:Is it possible to put the photo gallery link into your first post of this forum for easy access?
Added the link to the first post.
Posted: 04 Feb 2018 13:35
by 66DUCE
Nice work guys I feel your pain, as we are in same boat with battling the rust monsters! Keep up the great work!
Posted: 04 Feb 2018 13:38
by MarkReidHRC
More progress:
J-Rod polishing chrome trim.
K Breezy filling holes.
We also removed the battery base in the engine bay. The battery will get moved to the trunk.
Used a copper backer to fill in small mounting holes in the engine bay.
Posted: 08 Feb 2018 21:11
by MarkReidHRC
Work is steadily progressing. Started removing the rocker panels and fixing more rust holes.
Rust behind rocker panel to fixed.
Removed the bad stuff ready to rebuild.
Fitting in the new sheet metal.
Not the most pretty piece, but considering it was made with a hammer and pliers it's not to bad.
Backside welded and primed.
Posted: 08 Feb 2018 21:31
by gooned
You guys are killing it!
Posted: 08 Feb 2018 22:28
by Heinrich
awesome, keep at it.
Posted: 10 Feb 2018 20:29
by MarkReidHRC
Patching inner rear wheel housing on the right side.
Trimmed and primed ready to install rocker panels.
Fitting in the rocker panels.
Checking fit with the doors on.
Other side with Futofab fender and rocker panel.
Posted: 11 Feb 2018 08:04
Progress is really coming along.
Fabrication of the complete dog leg section of the door jamb, especially on the drivers side looks like it’s going to be a real challenge. That’s a huge section of material missing.
Good that you are confirming fit of the panels as you move along. And also quite fortunate that the bottom of the doors themselves were in good shape, considering other areas which were quite gone.
Hats of to the whole crew at home. What a great family project.
Posted: 13 Feb 2018 08:50
by qwik510
MarkReidHRC wrote:More progress:
Looks amazing so far.
You should take the time to fill in the indent on the fender well where the battery tray used to be. Having both fender wells smooth and symmetrical will give the engine bay a much nicer finished look. Some people have put a cut in the metal, hammered it out and then rewelded it.
Posted: 13 Feb 2018 21:13
by MarkReidHRC
Quik510 We will add that to the list. Good idea.
Posted: 13 Feb 2018 21:28
by MarkReidHRC
Fitting the outer wheelhouse in. The flange around the top of the wheelhouse is 100% welded to the inner wheelhouse. (not spot welded) This makes removal a tedious job.
Carefully removing the old flange in behind the section of door jam.
Outer wheelhouse fitted. Next the trunk drop and quarter panel.
