L 30 stroker startup
http://www.youtube.com/watch?v=EzYiq9-i3NY
Took a vid of the motor during startup with very rough ignition and fuel maps.The AEM EMS system works well once several bugs were figured out.I do plan to move the cam position sensor from the modified distibutor and put it directly reading a tooth on the cam sprocket via another VR sensor.
RE: L 30 stroker startup
RE: cam sensor
Click here to have a look at the data sheet for Melexis P/N MLX90217LUA
Click here for more applications data for hall sensors
DigiKey sell the MLX90217LUA for around $6.50 ea. Using a few basic bits and some wire, you could whip together a pretty neat cam sensor using this part - a cam sensor that is capable of reading true lobe position, not a reference magnet. The sensor has an amazing -40°C to +150°C range too
Another good sensor is the Melexis US5881LUA. Same temp rating, but just a unidirectional binary field sensor, for only $1.66 ea from DigiKey
just some food for thought...
WWHHAATT...a UNIDIRECTIONAL BINARY FIELD SENSOR...do I need one of these?
I have room on my dash....
- supersportsedan
Come on Keith, get with the times. I've got 3 of these glued to my dashboard.
That's a different kind of forcefield Paul; you are picking up some serious and majestic glory rays with that fantastic array of sensors & antennas! Man, and here I was talking about a regular old magnetic hall sensor...
UNIDIRECTIONAL = unipolar = doesn't monitor for reverse field polarization...
BINARY = when field strength is sufficient, signal transitions from binary 0 to binary 1 (i.e. there's no linear range between 0 and 1)...
FIELD SENSOR = it's just a magnetic field...
It's the first sensor that I mentioned that is the true gizmotron unit - THAT one is a 3-pin digital & analog self-adjusting field sampling sensor that has 10-bit S&H, 4-bit hysteresis, immunity to field alignment problems, no chopper delay. Man, now if you want to talk nerdy about sensor, THAT would be the one to discuss... the other one is old-school compared to the new one! The old one is like an old 3140 sensor! Ha - that is old! Ha. Ha ha. Ha HA ha neee heee hee hee beeep beep bep beeeeeep blip boooop booop click beep click meeeep...
- supersportsedan
Re: RE: L 30 stroker startup
Rob, I always knew that you had lost it, but now it's really starting to show...510rob wrote:Ha. Ha ha. Ha HA ha neee heee hee hee beeep beep bep beeeeeep blip boooop booop click beep click meeeep...
RE: Re: RE: L 30 stroker startup
The only problem is that my EFI system is setup to read only Variable Reluctance sensors and Ford ones at that.I have a small threaded VR sensor that is going to be mounted in the fuel pump cover and will read a "tooth"(bolt) that`s threaded in the camshaft sprocket.
thanks Rob 2000i. that's some good reading.
how big is your hard drive to know/remember/store all that knowledge?
richard norrish
No what`s scary is I had to do a bunch of research on sensors to figure out what would work in my setup and I actually understood what Rob was talking about..in detail even.AEM EMS ROCKS
what 1/4 mile times are you shooting for now?
Better than before:). I am hoping for 600rwh with a Precision SC63 turbo and around a 100rwh shot of N20.Mid-low 10`s mabey.Plus it would be too cool to put some hurts on the idle Viper, Porsche, C6 Vette ect...
