'72 Wagon: Bueiz
bueiz
'72 Wagon: Bueiz
Post by bueiz » 02 May 2007 21:10
I figured I'd start a project thread so here it goes....
As some of you may know my 1st 510 Wagon flooded during Katrina. Here I am starting a thread for my 2nd 510 Wagon. I bought this one completely original, but I'm not an original kind of guy.
You can find pics of both wagons and any happenings on my website here: http://deliberate-damage.com/datsun/datsun.html
bueiz
Post by bueiz » 03 May 2007 04:36
Here I'm working on restoring the hood from the flooded wagon for the new wagon. After getting the new wagon I got into a bit of a fender bender thus the swap: CLICK - Restoring Hood
bueiz
Restoring Katrina Steering Wheel.
Post by bueiz » 03 May 2007 04:58
Here are some pics of my Steering Wheel restore. This Grant Steering Wheel was in the wagon that flooded during Katrina. You can see wear the wood split from soaking in raw sewage water for two months. I sanded it down and applied a quick coat of Polyurethane; I also added a little note to for a little extra touch. Attached to the steering wheel is the Grant Steering Wheel Hub Disconnect.
bueiz
RE: Restoring Katrina Steering Wheel.
Post by bueiz » 18 Jul 2007 14:51
I have a 32/36 DGV and it's been cleaned and rebuilt; do I need to add any kind of gasket sealer/sealant when putting it back together?
hang_510
Post by hang_510 » 18 Jul 2007 16:39
no.
bueiz
Front Valence Removal & Replace
Post by bueiz » 24 Jul 2007 08:53
How have some of you been re-attaching front valences after drilling out the spot welds for removal?
RE: Front Valence Removal & Replace
Post by Byron510 » 24 Jul 2007 09:01
I have bolted them back on by placing captive nuts on the reverse side. An M6 bolt tucked under the lip, and at each spot weld does go unseen. Since the valence panel is there only as a filler panel, it server no structural purpose, so welding it back in place is unnecessary. I did this on my green ’68 4dr.; no one ever noticed that the valence panel had been converted to a bolt on unit.
bueiz
Exhaust Manifold Gasket...Sealer?
Post by bueiz » 06 Aug 2007 20:01
When replacing the exhaust/intake manifold gasket do I need to use any type of sealer when reinstalling?
RE: Exhaust Manifold Gasket...Sealer?
Post by Byron510 » 06 Aug 2007 20:10
I actually use never seize, just so these parts will come off again easily! (and no, it never leaks)
No sealer is required - as long as both surfaces are clean and flat. RTV is for lazy people who don't like to completely clean off old gasket from the surfaces... Usually old bits left behind will eventually leak in that area anyways. Best to get it all clean.
Another common problem I've started to see is that the old exhaust manifolds are no longer flat, or are corroded and pitted on the gasket surface. Here again, no amounts of RTV, no mater what temperature it is, will seal this for long. Eventually it will leak again. Often the exhaust manifold needs to be planed at your local machine shop.
Just a couple hints, but you shouldn't need any RTV or other sealer if all the parts are in good condition.
Post by defdes » 06 Aug 2007 21:32
I have in the past use a bit of the copper spray on the exhaust only, after all, the intake is sucking, the exhaust is blowing.
rnorrish
Post by rnorrish » 06 Aug 2007 23:52
i've put a little grease on the intake manifold before bolting up, for the same reason as Byron - easy removable, and re-usability.
richard norrish
bueiz
Re: Project '72 Goon: New Front Valence - GOING Detachable.
Post by bueiz » 01 Feb 2008 11:17
I'm picking up a new front Valence today!! Got it from a Nissan Dealership about an hour away for $190 + gas to get there. :D
I'm going to make it removable with some ideas from Byron510. I'm replacing it after my little incident a while back: http://deliberate-damage.com/datsun/72wagonwreck/ it wasn't MAJOR damage (luckily), but I'm not body guy. I wish I know how to do to bodywork and I think I'll remove this one and the one from the Katrina-Wagon and learn a bit...straightening and painting. I'll post pics of the new valence once I have it.
hang_510
Re: Project '72 Goon: New Front Valence - GOING Removable.
Post by hang_510 » 01 Feb 2008 11:31
did insuarnce cover the damage?
bueiz
Post by bueiz » 01 Feb 2008 11:39
Nah man...I wish. I only have liability on the Wagon. Here in New Orleans insurance companies eye gouge and skull "hump" the life out of people. Their excuse...uninsured motorists, total BS in my opinion. I was paying $35 a month for full coverage on the Katrina-Wagon when it was registered in Florida. Luckily I had just registered it in Louisiana when Katrina decided to make an appearance! :evil:
bueiz
Re: '72 Wagon: As Blue as the Night is Bright.
Post by bueiz » 19 Jun 2012 12:21
So I pulled my stock Brake Master Cylinder off yesterday b/c the brakes weren't working and I noticed some grunge at the bottom of the reservoirs. It's toast.
So I have a 5/16" replacement, but realized some differences, main one being that the push rod from the stock MC won't work with the 5/16" MC. Maybe it will? Any suggestions?
I can see that I'll have to re-run some brake lines to get them to match up to the 5/16" MC. Never done that before, but I'm sure it'll be super fun to do.
