SR SR20 SR20DET radiator choices - REAL info
htownsr510
Re: SR SR20 SR20DET radiator choices - REAL info
Post by htownsr510 » 06 Feb 2010 15:22
I plan on running this cx radiatior with slim fans and samco hoses
vdubjim
Post by vdubjim » 18 Mar 2010 17:10
From ratsun, the ebay rad:
sssr20det510
Post by sssr20det510 » 18 Mar 2010 17:52
spoolinitup33 wrote:One more thing. That Ron Davis radiator that I and S15DET are using, part #1A-22163 is only $279.00, not $450. You only have to modify it like I did if the engine is sitting in the stock location, if you have it moved back towards the firewall some, you won't need to modify it.
Nice i Thought it was 450, 279 sounds more affordable do you have demensions on it
vdubjim
Post by vdubjim » 18 Mar 2010 20:17
Ya apparently, on their site it shows 450, but when you call to order its cheaper.
spoolinitup33
Post by spoolinitup33 » 19 Mar 2010 20:38
sssr20det510 wrote: Nice i Thought it was 450, 279 sounds more affordable do you have demensions on it
It's 22"x16" and it's 3" thick.
vdubjim
Post by vdubjim » 17 Apr 2011 14:01
Saw another good one. Its what VG30 people were using too.
Griffin $179
http://www.summitracing.com/parts/GRI-1-25241-XS/
From Rpowell25
RonM
Post by RonM » 17 Apr 2011 18:21
Here's an interesting option if you'd like to get more out of your existing Rad, or inter-cooler. There is a coating made by NIC called C-187 Transfer Black that acts as a surface thermal dispersant. Check out the site http://www.nicindustries.com/heat_dissipation.php I wish I had some hard data to share, but I've read it improves heat diffusion by 30-40% Please bare in mind this is purely hear say, but even if it were 15% it's worth considering. My inter-cooler is being coated with the stuff right now, so we shall see.
cartel
Post by cartel » 29 May 2019 15:53
just to update this - i called ron davis last week and the 1a-22163 i was told $550 -- they also sell it with fans and shroud for $742. not even close to the earlier posts yes its been 8 + years but thats a lot of price increase-
not sure if i like the "look" of the cx racing rad so im likely ordering a howe 342bm which is 23 x 16 x3 or the summit one listed before of 24 x 16 x 1.75 just not sure if i need the 2 core --
Mike Gibson
vdubjim
Post by vdubjim » 29 May 2019 16:08
Blast from the past!
Jesus for a rad? Big nope.
Stu
Post by Stu » 17 Apr 2020 13:24
With a CX Racing SR20 radiator, I ended up using Gates 23372 on the upper and Gates 22515 for the lower on my car.
http://www.the510realm.com/viewtopic.ph ... 64#p279865
Stu
72 4-door 510
Factory Five Racing Cobra
2005 Mini Cooper S
91 Ford F250 4x4 extended cab
