Best place to get L series parts?
Rheis
Post by Rheis » 14 Jun 2010 20:04
So seeing as how no one has noticed my post in my project thread ... http://www.the510realm.com/viewtopic.ph ... 0&start=30
the block went to a machine shop to be honed and it turned out great. They also took a look at the pistons to make sure all the clearences were correct, removed the old rings etc. Unfortunately #4 has a broken 3rd ring land. The good news is its a Nissan piston. It measures aprox 86mm diameter and 38mm from center of pin to top (measured with a crappy plastic caliper) it has the nissan emblem stamped inside the skirt with a 4 beside it. Opposite inside skirt marked AT5U61 and the top of the piston says STD P90. According to Jason Grey engine spec page I asssume it is "L28 (early)---------- 38.1mm /10.90cc dish in 280Z, early ZX.('75-'80)/ 86mm bore" So where should I get this piston from? I have heard going to the Nissan dealer is expensive but if the quality is better and it will be exact same who cares about $. Also is the dealer where I should pick up my rings and bearings? what kind of rings? moly.. chrome..?
thanks
this is for my turbo motor btw
thanks
Re: Best place to get L series parts?
Post by bertvorgon » 14 Jun 2010 21:08
Why don't you go to Andy?
iceD
Post by iceD » 14 Jun 2010 22:12
He is the best of the best (think Top Gun), and he is local to you. And you can even walk your dog at his new location, on beautiful Boundary Bay; at the bottom of 104 Street, just off Highway 10.
ice D :!:
http://www.specialtyengineering.ca/
jason
Post by jason » 14 Jun 2010 22:13
To prep your block and get the bottom end ready, I think you're best off with Andy Rheis ....
Rheis
Post by Rheis » 15 Jun 2010 14:27
The funny thing is the PO had all the bottom end preped by Andy :D ... I was thinking he is the best man for the job but I was hoping to get some experience and save some $.
jason
Post by jason » 15 Jun 2010 16:27
I hear you Rheis, but, my 'goon is there right now and being worked on as we speak. Join me in being broke :lol: !
