Guys,
I was fortunate to find this unit at my local pick-n-pull .I need your input here, Ive read countless threads and can't seem to find the answer to my question.
Is there a write up on what parts are needed to mount this LSD unit in my 2 door 510 as far as the half shafts mounting to the subie unit.
Does any one make a cv conversion for the 510 or know of a way of doing the upgrade that will mount to this R160.
Thanks in advance.
Vince
2006 RI60 Outback XT limited 2.5 turbo 5MT LSD
- eastbaysolo_73
My build thread
Nor Cal Meng !
My build thread
Nor Cal Meng !
Re: 2006 RI60 Outback XT limited 2.5 turbo 5MT LSD
DQ Volume 9 Issue 4 - Tech How-To: VLSD Installation - Subaru VLSDs are now more common (and cheaper) than clutch-pack R160s. Australian Peter Otzen documents the fabrication necessary to use 510 half shafts and make the installatino a bolt-in.
or
DQ Volume 11 Issue 2 - Tech How-To: Subaru VLSD Adapters — Robert Powell shows how he installed the Subaru VLSD into his 510. This method differs from DQ 9.4 as Robert wanted to retain his CV axle setup that uses the VW Type-II CNC adapters.
or
DQ Volume 12 Issue 4 - Tech How-To: Installing an '06 Subaru STR-R R180LSD — Beta Motorsports 27T stubs create new possibilities. Accessorize your new differential with a Perrin large-capacity diff cover.
If you want to convert from halfshafts to CVs, there are also companies that are making complete bolt-on kits to do so using the VLSD.
And:
viewtopic.php?p=202717#p202717
The information is out there.
or
or
And:
- eastbaysolo_73
okayfine wrote:DQ Volume 9 Issue 4 - Tech How-To: VLSD Installation - Subaru VLSDs are now more common (and cheaper) than clutch-pack R160s. Australian Peter Otzen documents the fabrication necessary to use 510 half shafts and make the installatino a bolt-in.
or
or
And:
Thank you very much for pointing me in the right direction. Very much appreciated.
My build thread
Nor Cal Meng !
My build thread
Nor Cal Meng !
