DOHC on a SOHC engnie.
- two_68_510s
Re: DOHC on a SOHC engnie.
Are you trying to justify a lathe?;)
- Mattndew76
two_68_510s wrote:Are you trying to justify a lathe?;)
I wish I could get a lathe. But for now I can make these on the mill. Justify the purchase of a boring head maybe and a broach arbor....
This motor would prolly be ready for a test run if my commute to my man cave wasn't 50 miles one way lol. House shopping tonight...
- Mattndew76
I was reading on the 1200 site about the A12 - B Head build thread and had seen where a person had posted that they went with larger pistons but offset the cylinder bores for 2 and 3 to match up perfectly with the combustion chambers on the head.
QUESTIONS:
How can you offset the cylinder bores for cylinders 2 and 3 with there being no play on the crank shaft to connecting rods?
Would the offset now be needed in the wrist pin connection within the piston?
QUESTIONS:
- IMG_3808.JPG (287.02 KiB) Viewed 4035 times
You'd definately have to change the crank if you changed the bore spacing, no small task!
- Mattndew76
Exactly.. I believe the guy who did this originally just went ahead and lined up the front and rear combustion chambers - cylinder and lived with the 4.445 mm offset chamber on cylinders 2 and 3. Since its a non interrupt head the 2.5 mm ledge must not have hurt anything.Byron510 wrote:You'd definately have to change the crank if you changed the bore spacing, no small task!
I cant get any answers out of the Aussies. The one guy who is speaking for the OP on the site wants me to buy the kit they sell. I don't want to buy the kit. It looks marginal at best and I can design my own.
EDIT: If I bore over sized to a 78mm piston it takes the ledge away but still leaves the combustion alignment off by 4.445mm
I would think that you could relatively easily reshape the combustion chamber with a die grinder and TIG welder. The spark plugs may not end up in the optimal position, but you wouldn't have any ledges to worry about.
- Mattndew76
So I looked a little bit more into the spacing. Me on my back looking up through the block at the heads alignment. I think I can leave everything as it but mill new valve relief in the top of the block. I can mill a 3.175mm head gasket and just force feed this thing airduke wrote:I would think that you could relatively easily reshape the combustion chamber with a die grinder and TIG welder. The spark plugs may not end up in the optimal position, but you wouldn't have any ledges to worry about.
- IMG_3729.JPG (451.49 KiB) Viewed 4012 times
- Mattndew76
So i made a 3D rep of the head chambers to block cylinders. The inner 2 and 3 cylinders already have .100" deep valve relief cutouts. So I figured I might just go a little more with what I have to work with and mill my own relief in the block.
The cylinders 2 and 3 are .100" mismatched from combustion center and 1, 4 are .075" mismatched off center.
Red = Block
Gray = Gasket / head chambers
Red = Block
- Block to Gasket-2.JPG (99.43 KiB) Viewed 3969 times
- Block to Gasket.JPG (116.33 KiB) Viewed 3969 times
- Mattndew76
Got 3 more jobs of Datsun parts and then I can thrown the block + Head into the CNC for some mod work.
Oredered:
*Main Bearings + Seals
*Rod Bearing
*Timing Cog Pulley
*Timing belt Kit ( Cog Idler, Tension Idler, Smooth Idler. )
Right now I am sourcing brass pipe thread plugs for the Engine Block and Head. I need to block those passages off.
Total Frankenstein.... With slightly off center combustion ha ha ha
Oredered:
*Rod Bearing
*Timing Cog Pulley
- Mattndew76
Crank shaft timing gear was waiting on my door step when I got home.
A12 Crank shaft drive post diameter is 1.125" Or 28.575mm
The I.D. of the Mazda crank shaft timing gear 1.065" or 27.051mm
Its made of some hardened steel.
I was curious if I could remake this part from 7075? I imagine with a .004" black hard anodize this would have plenty of wear resistance to the Rubber-Kevlar cog belt.
Key seat would have no play, so no torque wear would occur from that.
I am going to try this out.
Mattndew76 wrote:I am going to try this out.
- Mattndew76
Im making this a non-interrupt valve-train. So if any fail in the timing system this will not damage the project. Just a "oops lets try this again."
Im excited to get this fired up. I need to fab up an engine stand for firing this up outside the car.
Love this thread Matt!! Keep's me entertained on my saturday's at work, Keep up the awesomeness!
I love this whole thing - Can't wait to see it running
You might be able to cut the timing gear with a carbide bit or grind. How about turning the crank down .060 or a combo of the two? Seems to be a lot of work to make a new gear and have it anodized.Mattndew76 wrote:Crank shaft timing gear was waiting on my door step when I got home.
