Actually, it's good that you reminded me of that! We did have to mill off a hair off the top of the crankshaft bolt head. Mine had been hitting ( just ) with no noise at all. We only discovered it when my sprung 4 pucker failed.
Something to check for sure!
Stock or aftermarket clutch and flywheel?
Re: Stock or aftermarket clutch and flywheel?
Hey Rob.Like Keith said ,I got Andy to trim a tad off the crank bolts so avoid any issues.Greg, did you have any clearance issues?!? I seem to remember something about the height of the bolt heads holding the flywheel to the crank.
- rsz_100_7477.jpg (196.13 KiB) Viewed 2109 times
Not to mention using the wrong bearing sleeve to start with
- 100_7483 (Medium).JPG (112.58 KiB) Viewed 2104 times
- 100_7484 (Medium).JPG (96.89 KiB) Viewed 2104 times
- funwithmonkeys
That flywheel looks a lot like this. http://www.thezstore.com/page/TZS/PROD/ ... 2a/21-2065
- KiKiIchiBan
I've spoken to Oleg, very helpful.
I guess the disc is 200mm o.d, ( 7-7/8" ) with a 1 X 24 teeth spline?
