2.3L L20b custom tri-y piping size
Hello all,
Have a quick question on header piping size. Would a stepped piping size of 1.5in primary 1.75in secondary and 2in collector. Or a 1.75in primary 2in secondary and 2 1/8in. Will these piping sizes be to large for a 2.3L l20b efi itb and cam in the neighborhood of 290-300/.485-.500, a87 peanut chamber head ported with largest stainless valve you can fit, to a 2.25in exhaust. I'm trying to beef up the midrange to transition better into the cam powerband.
Any insight would be appreciated.
Gumby
Gumby
71 PL510
92 rhd 180sx
01 s2000 aka skidmark
03 wrx winter car
92 rhd 180sx
03 wrx winter car
Re: 2.3L L20b custom tri-y piping size
In general, a smaller tube size increases torque at the expense of top-end. You could probably take a look at headers for KAs and see what size tubes they're running. I'm pretty sure most of them are just straight 1.625 primaries, and most are also 4-1, so no secondaries. I'd suggest sticking to 1.625s, but extending the collector as far back in the system as you can, to enhance torque.
Thank you,
With looking over what the ka uses primaries range from 1.5-1.75 and are split if there a 4-1 or 4-2-1 (only found 5 different designs). In that aspect there not to different from the s2000 f20c piping sizing.
I was planing on having the mid to 3/4 point of the secondary be at the firewall and the collector end a littlbiways before the shifter. Still have some numbers to crunch and a bit more research to do (still a novice at some of this stuff)
71 PL510
92 rhd 180sx
03 wrx winter car
92 rhd 180sx
03 wrx winter car
You're spec'ing a decent cam, but KA pipes are built for the larger exhaust volumes from the dual exhaust valves.
Thanks again, your insight is always appreciated. Think I'll probably go with the stepped 1.5in primary-1.75in secondary with a 1 7/8 or 2in collector. Still have to looking into a few things.
71 PL510
92 rhd 180sx
03 wrx winter car
92 rhd 180sx
03 wrx winter car
Might also look into the reverse cone, taper from a 2" collector to your 2.25" mid pipe. Some information at Burns Stainless.
For that monster motor I'd go 1.75 Tri-Y design 32" in lenght total. l do cylinders 1-4 mating at the Tri-Y and cylinders 2-3 mating at their Tri-Y with primaries as equal lenght as possible. The reverse cone taper mentioned by Jules is a very good point. Personally I'd built that header for mid to top end. I have a headers for my NA S14 SR with these exact dimensions.
For that monster motor I'd go 1.75 Tri-Y design 32" in lenght total. l do cylinders 1-4 mating at the Tri-Y and cylinders 2-3 mating at their Tri-Y with primaries as equal lenght as possible. The reverse cone taper mentioned by Jules is a very good point. Personally I'd built that header for mid to top end. I have a headers for my NA S14 SR with these exact dimesions.
I was planning on doing equal length runners. What is your reasoning behind the 32in total length. Seems a little short.
71 PL510
92 rhd 180sx
03 wrx winter car
92 rhd 180sx
03 wrx winter car
Is what my header design length is, weird I know but it can easily be tuned longer at each Tri-Y.
