Z24 + KA24 = 300hp for a 510 in AU
S15DET
Post by S15DET » 27 May 2015 04:43
Re: Z24 + KA24 = 300hp for a 510 in AU
Post by okayfine » 27 May 2015 06:15
It would be interesting to know why they went Z24 instead of just working over a full KA24DE.
Post by datzenmike » 28 May 2015 17:46
Only thing Z24 about this is the block. It would be lighter. Cylinders walls might be thicker than a KA?
Post by JordanTr » 28 May 2015 22:23
KAs are less common in oz as well I believe since they got a 200sx with SR instead of the USDM/CDM 240sx with KA.
duke
Post by duke » 28 May 2015 23:07
JordanTr wrote:KAs are less common in oz as well I believe since they got a 200sx with SR instead of the USDM/CDM 240sx with KA.
I think this may be the main reason. They only got the KA in FWD guise. If you look closely at the head, you will notice that it is different than the RWD KA head.
This engine is awesome! I have heard that the Nissan Pro Lite trucks that ran the KA24de got around 350hp normally aspirated...but they were spinning them to 9000 rpm and rebuilding them after every weekend!
Post by Byron510 » 29 May 2015 03:13
Duke, thanks for your input on this.
What I have never understood is why go SR in our marked flooded with KA's? Turbo kits including beefier rods and pistons are quite cost effective, and parts are available off the shelf!
The SR out of the box is certainly cost effective if one wasn't going to rebuild it. But with the age of the SR's now, a used motor just doesn't seem to be the way to go in my mind.
It would seem that a mildly aspirated KA with a induction, cam and header is capable of over 200 HP, matching the stock SR's output. Once both engines are turbocharged, I wonder if there really is much of an advantage to the cylinder head architecture. Maybe the SR guys can chip in here on the discussion?
KCMO_68
Post by KCMO_68 » 29 May 2015 05:58
I have a Rebello Z24/KA24, but it only produces 245HP Naturally Aspirated. It's rev limit is around 7200rpms, but it's setup so that it still works on 91 pump gas.
Here is the dyno sheet from Rebello: Image
OUTthere
Post by OUTthere » 29 May 2015 13:20
KCMO_68 what parts are used to make that combo? I'm thinking it might be a z24 shortblock with the ka24de head due to the rpm's but would love to know for sure. Recently seen a Rebello L engine that impressed me enough to try to make one using a z24 crank that doesn't require the use of race/jet fuel.
Post by datzenmike » 29 May 2015 19:32
Custom crank. The Z is not nearly fully counter weighted enough for those RPMs.
Post by Byron510 » 29 May 2015 20:20
KCMO_68 wrote:...but it only produces 245HP Naturally Aspirated.
God damn man! That's more than enough to get into trouble - especially on a NA engine.
Also interested in the parts utilized. Did it use a single or double roller chain?
Post by 510rob » 29 May 2015 20:38
2 cams & 16 valves, or 1 cam & 12 valves?
OUTthere
Post by OUTthere » 30 May 2015 07:54
I was lead to believe it's a ka24de head because the Rebello print out lists the engine as a LZ24DE. Just can't stop thinking about the crank that is spinning 7000+ rpm's. Maybe welded up the z24 crank so it's fully balanced, the L head I seen Dave work on that flowed 600+ cfm impressed the shit out of me!
Post by defdes » 30 May 2015 15:44
Even with Rebello's 10% generosity with his dyno, those are still good numbers.
Post by datzenmike » 30 May 2015 16:49
lultz.
It said custom crank with longer stroke and 2.6 liters displacement
datsun510
Post by datsun510 » 31 May 2015 23:11
We just bought 2 pro Lite engines. They used Truck blocks that did not have the girdle, engine builder said caused too much windage in the engine and they had problems with stock oil pumps not surviving so they were dry sumped. Also since they were dry sumped with a ARE oil pan which adds the strength back to the bottom of the block. The person we bought them from said they were good for about 300 HP with 48mm webers and 42 mm chokes, could gain about 15-20 HP with 44 mm chokes with a loss of low end. He would run the engines to 8500 but said other teams with unlimited budgets would run as high as 9500.
