excessive oil out of block breather
Dimes4Life
Postby Dimes4Life » 18 Apr 2016 19:50
Today while I was driving on freeway..I smelled burning oil and saw smoke coming from tranny shifter hole..drove home jacked it up. Didn't see and puddles block & tranny were relatively dry but I did see a burned hole in the hose connected to the block breather tube...looks like either header burned a hole in hose or excessively hot oil is shooting out onto header. i ran this hose for 2 yrs & never had heat ussue although it was a heater hose connected..found a place here in bay area that supplies 1/2 inch fuel line and other huge size hoses
My question is that I thought only vapor came out this breather tube..if header burned hole...ill look for relacement hose and heat proof tape. But why would oil start shooting out in first place?
SteveEdmonton
Re: excessive oil out of block breather
Postby SteveEdmonton » 18 Apr 2016 20:02
Looks to me like the hose has had several "close encounters" with a hot header, judging by the melt marks close by to the gaping hole.
Was the hose actually connected at both ends, or did one end maybe work free and then flop down onto the header? From your photo it looks like a properly connected hose "should" have enough clearance to avoid melting like that.
And you're right about the purpose of this line: the steel vent-pipe attached to the block simply vents vapours from the crankcase into your PCV valve. In the photo with the circles, that valve seems to be in an odd place. It's been a long time since I had a stock carb / manifold setup though so maybe it's normal. In any case, I don't think it's plausible that hot oil was inside that rubber hose. And even if it was, I don't think it's plausible that it would have melted that hose.
So again, is it possible that this hose contacted your header? Are there any traces of melted hose on the header that might point in this direction?
G'luck! :)
'71 4-door
'74 MGB-GT
'04 Miata
Postby two_68_510s » 18 Apr 2016 20:04
What Steve said ^^^^^That sure looks like the header burned it, you have areas that are charred from the outside, my dear Watson!
Dimes4Life
Re: excessive oil out of block breater
Postby Dimes4Life » 18 Apr 2016 21:28
Thanx for response..the hose did touch the header...all the vibration made it ease off the vent pipe and rub on
the header. I replaced the hose and made sure it doesnt touch anymore...will test again tomorrow.
BTW..I. couldn't find any burned rubber or residue on the header. The semi-circle shape looked like header melt.
Postby okayfine » 19 Apr 2016 06:03
Hose clamps. Get some.
Postby datzenmike » 20 Apr 2016 16:37
Find a hose that is petroleum resistant. Oil and gas dissolves real rubber.
Return to “Powertrain”
