L16 Issues. Confirm my worst fears
Re: L16 Issues. Confirm my worst fears
Postby RMS » 09 Jun 2016 11:40
my one and only matchbox dizzy will find its way into the 68 unless someone wants to pay $120. I have over a dozen L16 cores and they are hardly worth the time taken to strip the mounts hardware pan and pickup to one day sell or trade to someone doing a L20b.
I do have an optical dizzy with a crane box whos full potential will never be realized on a stock to mild street Lseries
im not getting rich off datsun parts, i only do it to get more 510s on the road and out of the weeds.
if it was not for my free storage it would cost me hundreds of dollars a month to keep this stuff and I have to listen to the woman bitch every time I sell something as its is usually well under market value.
Im not makethemoveto or Tokyo to, im just a datsun nut
Chickenman
Postby Chickenman » 09 Jun 2016 12:55
OK... well you do have to adjust the Primary jetting up a bit when you run the PCV valve, compared to a non PCV tune. It is basically a controlled vacuum leak. And do make sure that you are running the correct Datsun PCV valve. They are flow calibrated to the engine size.
LifelikeStatue
Postby LifelikeStatue » 11 Jun 2016 19:11
So my father in law came over with his compression tester and we took a look. 150, 150, 150, 70. Cylinder closest to the firewall, 1 or 4, is way down. We added a little oil right in the spark plug hole and it came up to 110. Rings are toast. RMS, save me that engine and that matchbox dizzy. $320 for both. I'll send a PM when I'm ready. Hopefully pretty soon.
It is better to remain silent and be thought a fool than to open your mouth and prove it.
Postby RMS » 11 Jun 2016 19:51
sounds good.
Chickenman
Postby Chickenman » 12 Jun 2016 19:13
RMS wrote:my one and only matchbox dizzy will find its way into the 68 unless someone wants to pay $120. I have over a dozen L16 cores and they are hardly worth the time taken to strip the mounts hardware pan and pickup to one day sell or trade to someone doing a L20b.
You are probably a dead man if, or at least seriously concussed by " The Marble Rolling Pin of Doom ", if a certain Lady sees this... :shock:
Postby RMS » 12 Jun 2016 20:48
:lol:
if it was not for her I would probably give most parts away.... because I would feel bad ....ya know poor guy puts in a new motor and spends the night doing burnouts then eventually breaks a control arm....you know Im going to want to help then point and laugh, take some pic's :mrgreen:
LifelikeStatue
Postby LifelikeStatue » 13 Jun 2016 13:54
Knowing my luck one burnout would grenade the rear end
Return to “Powertrain”
