Cam info
slowerthantime
Cam info
Post by slowerthantime » 09 May 2017 14:03
Can anyone help me identify this cam? Thanks.
Cam 1.jpg (388.54 KiB) Viewed 709 times
cam 3.jpg (368.29 KiB) Viewed 709 times
Re: Cam info
Post by 510rob » 09 May 2017 18:29
Perhaps an Electramotive L3? Partially by the back end markings, partially by the completely obliterated base circle. It must have about .580 lift at the valve, or somewhere around there.
Re: Cam info
Post by RMS » 09 May 2017 19:02
those adjuster looks pretty jacked.. hows the swipe on those rockers? would a lift like that require new valve springs every 1000 miles ?
slowerthantime
Re: Cam info
Post by slowerthantime » 09 May 2017 22:20
Did some digging. Electramotive Engineering sold to Nissan and became Nissan Performance in 1990...you guys probably know all that. So I took a look at the 1990 performance catalogue. If the Nismo L3 is the same animal as the Electramotive L3; it lists as part # 99996-D1019 with .620" lift/ 300 degrees
510wizard
Re: Cam info
Post by 510wizard » 10 May 2017 08:56
You aren't driving that on the street!
