510 2 door... diff posi question
Re: 510 2 door... diff posi question
Post by Byron510 » 29 Jun 2017 22:37
datrod wrote:For the folks that might need a set of side axles I have them stock. I have 6 pair in stock. $300.00 per set plus shipping. World wide shipping.
There are a couple other sources for these axles. But they all have copied my design. I started making these back in about 2007.
You can contact me thru facebook or e mail. facebook John Williams.
e mail wmi73@verizon.net
Thank you.
John, thank so much for posting.
Are these stub axles specifically for the CLSD R180 or can they work with the Torsen diff as well?
Also, what material are your stub a Les made from?
Thanks for signing up and posting.
eastbaysolo_73
Post by eastbaysolo_73 » 30 Jun 2017 13:57
Thank you.
I can answer one of those questions for you. In my previous post with the photo of Johns stub axel I stated Im running a 2014 STI Torsen LSD :mrgreen:
Nor Cal Meng !
rdanard
Post by rdanard » 02 Sep 2017 15:45
Thanks for the info guys!
I got my hands on a 2005 r160. Would these r180 adapters work? Not sure if the r160 and r180 axle shafts are the same.
eastbaysolo_73
Post by eastbaysolo_73 » 03 Sep 2017 15:58
No the spline count is different. They will not work.
Nor Cal Meng !
Post by Three B's Racing » 05 Sep 2017 05:05
They are only for a Subaru STI diff which is 27 spline. I got a set and there great, I also got the "D" bolts for these that press into the back side from Riley Curtis at Lynchburg Nissan. I put them in my freezer overnight then installed them. Simple tapping with a hammer and they were in like Flint.
datsun5104dr
Post by datsun5104dr » 05 Sep 2017 06:59
Three B's Racing wrote:They are only for a Subaru STI diff which is 27 spline. I got a set and there great, I also got the "D" bolts for these that press into the back side from Riley Curtis at Lynchburg Nissan. I put them in my freezer overnight then installed them. Simple tapping with a hammer and they were in like Flint.
any idea where I can get these pressed in stubs Lou?
-Mike
'68 Datsun 510 4DR
Post by Three B's Racing » 06 Sep 2017 04:46
Hey Mike
I sure do JOHN WILLIAMS <wmi73@verizon.net> but not sure if John would still have any. In any case there is always Futofab.
Post by Three B's Racing » 06 Sep 2017 04:47
or you talking about the Stub axle "D" bolts? those you can get from Riley Curtis at Lynchburg Nissan.
