Page 1 of 1
Swapping mount studs to bolt on Differential
Posted: 27 Jul 2017 12:08
by TheHeretic
Have to drop my tranny here in the new few weeks and want to swap out the studs in the diff cover to bolts to make R&R easier. What bolts do I need to buy and would lock washers be suggested as well? Found these?
https://www.belmetric.com/12mm-c-2_1046 ... 3t9b8nk785
Thanks in advance!
Re: Swapping mount studs to bolt on Differential
Posted: 27 Jul 2017 14:52
by zKars
Doing this stud to bolt conversion has saved me endless hours of hassle on Z's and 510's.
They are M12 x 1.75 threads in the diff covers for R160 and R180 you got that right. Lock washers are required.
Just measure the stud threads and get a bolt the same length. 30mm is probably just fine.
Posted: 27 Jul 2017 15:21
by James
Agree - did this, and the last time I had to remove it - it was so much easier. Highly recommended...
