240MM clutch experience
deano510
Post by deano510 » 17 May 2018 18:11
The KA24 engine and trans I'm removing has a 225mm Fidanza flywheel and clutch. I'm installing a newly rebuilt KA24 Rebello engine and trans and would like to use a 240MM Fidanza flywheel I have.
I've been looking for a clutch kit to fit this 240MM FW but without much luck. I have all 3 sizes of the TO collars to use.
Any help would be appreciated.
Dean
gzentas510@outlook.com
Re: 240MM clutch experience
Post by Byron510 » 17 May 2018 19:09
The 240mm clutches were used on the 720 4x4 and the 280ZX Turbo I believe.
A quick search notes Centerforce listing a couple different "Stage" clutches - whatever a stage means. They never list clamping force which is a way better rating indicator that a "stage" 1,2,999 ect. so it might take a phone call to get soe real information.
zKars
Post by zKars » 18 May 2018 07:07
The 74-78 280z 2+2 and the 82-83 ZX turbo's used a 240mm clutch. The zx turbo's also had a borg warner 5 speed, but I'm pretty sure the clutches were not different from the earlier 2+2 clutches. A quick Rockauto part number comparison will check that
zKars
Post by zKars » 18 May 2018 07:10
The 74-78 280z 2+2 and the 82-83 ZX turbo's used a 240mm clutch. The zx turbo's also had a borg warner 5 speed, but I'm pretty sure the clutches were not different from the earlier 2+2 clutches. A quick Rockauto part number comparison will check that. Now compatibility with the KA flywheel is another matter.
FYI, The Fidanza flywheel speced for the Z cars is drilled to accept both the 6 bolt 225mm and the 9 bolt 240mm clutch plates.
Post by JordanTr » 18 May 2018 09:43
Get a flywheel (possibly lightened) for an rb25 and use a z33 stock clutch.
Post by JordanTr » 18 May 2018 09:45
Ok. I didn’t read that very carefully. A 350z uses a 240mm clutch. Perhaps that will work for you?
Post by icehouse » 18 May 2018 13:17
SR20DET uses a 240mm clutch as well.
Post by datzenmike » 18 May 2018 23:11
JordanTr wrote:
18 May 2018 09:45
I think they are 250mm but 750 and 880 Kg clamp.
Post by Three B's Racing » 21 May 2018 04:38
zKars wrote:
18 May 2018 07:10
So the removable clutch disk plate is 240mm and wide enough for a smaller disk and is drilled and pinned and tapped for both the 225 and 240mm clutches? I've never seen that before unless maybe someone did some mods.
zKars
Post by zKars » 21 May 2018 08:18
Three B's Racing wrote:
21 May 2018 04:38
zKars wrote:
18 May 2018 07:10
Came new in a box. Factory drilled for both. 143281
Perhaps the confusion is I'm talking flywheel, not clutch plate.
Post by Three B's Racing » 23 May 2018 05:11
That's awesome as I've never seen a Fidanza structured like that Nice!!
