Transmission Mount Question
Beev
Post by Beev » 04 Jun 2018 07:16
Hello Again,
I am about to try and fit my 5 speed and cut the hole. I know it was running before in a 510 but I didn't get the cross member with it. I am positive once I put it in this will all become clear but if I can reduce the struggle why not. With my cross member from techno toy tuning and the shown transmission mount
https://drive.google.com/open?id=11FDq9 ... irKVUKgEUw
https://drive.google.com/open?id=146bXG ... z8r4RGHHGg
do I still need the rubber isolators that came on the transmission
https://photos.app.goo.gl/LCznPWPuLkKCaKq13
Many Thanks.
abisel
Re: Transmission Mount Question
Post by abisel » 04 Jun 2018 15:30
Your third picture looks like something from a broken mount. Your first two pictures are correct. However, the factory bolts for attaching the center mount to the transmission have a flat side to them and insert from top down so they don't turn when you tighten down the nuts. And the factory nuts are self-locking. But I suspect any m10 bolt,2 washers, lock washer and nut will work, but you may need to ground a flat on the washer under the bolt head to fit into the recess of the transmission.
Beev
Post by Beev » 04 Jun 2018 21:47
Thanks! I think I have it all sorted now. Just need to find the correct bolts in the bin of all bolts...
Post by Three B's Racing » 05 Jun 2018 06:22
Beev wrote:
04 Jun 2018 21:47
Wouldn't the bolts from the auto trans isolator work if you have them?
Beev
Post by Beev » 05 Jun 2018 08:07
They would! However I didn't take the items out of the car and have multiple components for which all the bolts are centrally located in a big box. So it is literally finding the bolts.
