EGR taper plug?
Edm620
EGR taper plug?
Post by Edm620 »
Apparently Nissan made a plug for the EGR that fits a few models, pn is 14052-21R00. Anyone know if this is a currently available part? I'm not having luck doing a web search.
"If you don't know where you're going, any road will take you there"
Ugandan Proverb
Re: EGR taper plug?
Post by datzenmike »
This appears to be for plugging the EGR tube hole on the exhaust manifold... for countries not requiring EGR?
Used on '84 and up S12 CA20 and '86- CA20E on the Stanza exhaust manifolds. Also the 2000 Maxima VG33DE exhaust manifold.
Edm620
Re: EGR taper plug?
Post by Edm620 »
EGR Taper Plug
EGR Taper Plug
Yes that is correct. Also on the KA.
It is a limited availability item, none found locally to me so I ordered one from US supplier - more cost in shipping than the part.
Apple (?) Nissan in Richmond(?) apparently has one in stock if anyone looking for such, and a few in Ontario.
Ugandan Proverb
Re: EGR taper plug?
Post by RMS »
would that be a BSP fitting ?
Re: EGR taper plug?
I have no EGR on my L20B and the TVV was broken and unused so I deleted it and used a core plug from a KA intake I had laying around. They are on all kinds of later engines in all sizes and not hard to find. Take an Allen set with you.
Re: EGR taper plug?
Post by 510rob »
JIS Tapered Pipe spec is the same as BSPT spec
Edm620
Re: EGR taper plug?
Post by Edm620 »
Not the same thing, this is a much larger diameter and machine thread.
IMG_5955 (2).JPG (44.44 KiB) Viewed 1171 times
The right part fits very nicely.
IMG_5960 small.jpg (117.45 KiB) Viewed 1171 times
Ugandan Proverb
