Another radiator question.
spoolinitup33
Post by spoolinitup33 »
I'm about to order a Spal electric fan and I was going to get some brackets that go onto the fan because it might work out good to where I can put a bolt through the lip on the radiator. But when I got onto the bracket page, it said it comes with a pin, a lock spring, and a rubber washer. I used to have a fan mounted on my 300zx and I just had those pins that go through the radiator holding it on. I don't really want to do that, but is there anything wrong with using those? I know they would probably eventually break, but can it hurt your radiator?
jason
Re: Another radiator question.
Post by jason »
Don't mount the fan that way! Mine was mounted that way by the PO. One of the ties broke on the last cruise and when the fan came on at a gas station, the fan flopping around let the blades contact the rad and punched a hole in the rad and shattered all the fan blades 50 miles from home :evil: ! Take a look at Byron's build for the Bronze. He mounted 2 9" "Zirgo" fans on the front of the rad support behind the grill and pushes the air through the rad. I redid mine the same way copying Byron, leaves a lot more room in the engine bay!
Post by okayfine »
If you've got mounts on the radiator, I'd definitely use them versus the through-core zip ties. Depending on your eventual level of bling-ness, you could get something made. Or you could make your own mounts:
spoolinitup33
okayfine wrote:If you've got mounts on the radiator, I'd definitely use them versus the through-core zip ties. Depending on your eventual level of bling-ness, you could get something made. Or you could make your own mounts:
Well I'm gonna have to get some mounts made and welded onto the radiator, that's why I was kind of wondering about the zip ties, just to save money, but I can get it done correctly.
Post by bertvorgon »
http://www.the510realm.com/viewtopic.ph ... ud+project
here is a quick referal back to my fan/shroud project. The idea of a the mass of the fan, being hung from the rad, with those silly straps, is a recipe for disaster down the road, when vibration and fatigue take there toll. Jason found that out.
gooned
Post by gooned »
jason wrote:Don't mount the fan that way! Mine was mounted that way by the PO. One of the ties broke on the last cruise and when the fan came on at a gas station, the fan flopping around let the blades contact the rad and punched a hole in the rad and shattered all the fan blades 50 miles from home :evil: !
man that guy was a hack... :roll:
jason
Post by jason »
Yah, but it lasted like 15 years that way :wink: ! The solid mount is way nicer Jason!
spoolinitup33
Were the straps that you used plastic? You can get metal ones from spal. I've already mounted the fan on there, but I don't know if I like the way I put it on there or not and I'd like to just put a couple of those straps on there for back up.
jason
Post by jason »
I used 4 bolts on each fan this time and mounted directly onto the rad support! The plastic straps are what gave way.
