l20b spitting oil iut the breather on the valve cover.
Re: l20b spitting oil iut the breather on the valve cover.
before you pull the motor ck behind the the water pump in cause of cavitated front cover if you have water in the oil
I replaced the water pump 2 months a go and there where no sign's of cavitation
