Fuel pressure?
510Scott
Fuel pressure?
Postby 510Scott » 16 Sep 2011 09:26
i got a ka24e with dual webers and was wondering what the fuel psi should be to the carbs? ihave the stock 510 fuel pump, do i need an upgrade? and is there any bolt in upgrade?
Re: Fuel pressure?
Postby defdes » 16 Sep 2011 10:23
They like 3.5, I think the stock pumps run about 7, though I can't confirm. Plenty of people use the stock pump so if you are not having any trouble, I wouldn't worry about it, though you could put in a pressure regulator too which would be cheaper/easier than an electric fuel pump.
Re: Fuel pressure?
Postby okayfine » 16 Sep 2011 10:56
The stock 510 L-series fuel pump bolts to and runs from the KA/E? I had no idea.
rnorrish
Re: Fuel pressure?
Postby rnorrish » 16 Sep 2011 12:25
okayfine wrote:The stock 510 L-series fuel pump bolts to and runs from the KA/E? I had no idea.
I would only imagine if it was one from an early carbed truck motor...
Pictures?!
richard norrish
shardik wrote:My swap will be made of solid gold and it will run on puppy farts.
Re: Fuel pressure?
Postby defdes » 16 Sep 2011 16:49
My mental lapse there.
Sealik
Re: Fuel pressure?
Postby Sealik » 16 Sep 2011 20:11
Pics of these aforementioned carbs/setup???
Re: Fuel pressure?
Postby okayfine » 17 Sep 2011 09:00
defdes wrote:My mental lapse there.
The OP should own that one, not you.
Even if OP has the early carb head and is running a mech fuel pump off it, looking at the pictures of the KA/E head online it doesn't seem possible to use the stock 510 pump. The cam gear is larger/head is wider and would need a longer arm to reach the eccentric.
OP could provide some clarification...
510Scott
Re: Fuel pressure?
Postby 510Scott » 26 Sep 2011 21:27
heres a pic of my carb setup itshalf a stock ka24 manifold and half another manifold welded together. i bought the car like this and im not sure what fuel pump he ran, all i know is theres some big relays wired in the trunk. ill get some pics tomorrow.
carb setup.jpg (4.13 KiB) Viewed 3093 times
Re: Fuel pressure?
Postby okayfine » 27 Sep 2011 06:33
Tiny picture, small like mice.
Your question was answered in post 2. You don't have a stock 510 pump. Pictures sound entertaining, but you'll need to measure the fuel pressure and figure out where to go from there. If it's necessary to add a fuel pressure regulator, avoid the "dial-a-just" cheapos and get the 1-4psi Holley regulator.
510Scott
Re: Fuel pressure?
Postby 510Scott » 07 Oct 2011 13:09
how do i make the pics big like billboards?
Re: Fuel pressure?
Postby okayfine » 07 Oct 2011 14:44
You can attach pictures here up to 250K in size. Your picture above is 4K, so there's room for increased pixel count. Alternatively you can put them up somewhere else and link them here. Lots of threads in Website Discussion regarding hosting photos.
Re: Fuel pressure?
Postby two_68_510s » 07 Oct 2011 14:54
make it 800-1000 pixels across VERY BIG
1500
1200
or a little smaller
800
Re: Fuel pressure?
Postby okayfine » 07 Oct 2011 15:43
Pictures get scaled down to fit the width of your browser window. In my case both of Joel's pictures are the same size, at least until I maximize the window.
In any case, Joel, have you been holding out on us? This the first time I've seen your front plate and accessory setup. Impressive.
VelvetHammer
Re: Fuel pressure?
Postby VelvetHammer » 03 Nov 2014 08:05
okayfine wrote:Pictures get scaled down to fit the width of your browser window. In my case both of Joel's pictures are the same size, at least until I maximize the window.
Agreed! Great looking plate Joel!
Re: Fuel pressure?
Postby two_68_510s » 03 Nov 2014 08:26
(Sorry about the threadjack!) Updates in my build thread but here is a current photo of finished plate in aluminum:
Return to “Engine Swap”
