KA swap cross member flip??
miniman101
Post by miniman101 »
Hey guys, I'll be coming into a KA swap in a few weeks, I realize I'll have to cut and flip the cross memeber... thats fine. But I was wondering why It just cant be flipped 180 degrees and things bolt back in...? might be a stupid question, but just wondering...
thanks
Ash510
Re: KA swap cross member flip??
Post by Ash510 »
the suspension is conected to the cross member, and that part can't be flipped.
Post by okayfine »
And the bolt holes in the crossmember are not parallel with the frame rail - if you look the spacing is slightly narrower in the front pair compared to the rear pair.
RonM
Post by RonM »
Also the bolt hole themselves are tapered at one end.
miniman101
ok perfect, thanks for the info
Post by Byron510 »
What you describe has been done - core out the pivot area and weld it back in the opposite direction. However when that post cam up years ago, I did ask what this did to the actual position of the LCA mount fore/aft relative to the original position and I never got an answer. So until this is actually looked at...
miniman101
I forgot to mention I am a machinist...
hmm, I'll have a look at it closer to the time when I am ready for the swap and its a bit warmer out...
swag510
Post by swag510 »
miniman101 can u post pictures of process it will help a lot of people out there :)
Post by okayfine »
swag510 wrote:miniman101 can u post pictures of process it will help a lot of people out there :)
Crossmember flipping has been documented here on The Realm (by Byron, I believe) and also in DQ:
DQ Volume 9 Issue 2 - Tech How-To: Reversing the Front Crossmember -- One of the tasks necessary to swap a front-sump engine (like the KA24DE or SR20DE/T) is reversing the front crossmember. DQ describes a simple and effective method to accomplish this.
RonM
Post by RonM »
Swag.
This is what a flipped X-member looks like. I'm no shop god, but it seems fairly simple. Make a jig, two 90 degree cuts, two welds. This mod has been done many times and is a proven solution. On the other hand coring and flipping the pivot mounts may sound easy, but who knows what gremlins this might invite to the party. There is a common practice of cutting out and razing the the pivot mounts to help with lowering as shown in the second pict. so maybe there is an untapped potential for a two for one mod here.
Post by defdes »
Here are some step by steps too:
Post by defdes »
Continuing...
Post by bertvorgon »
Nice welding, non of the glob and slop I see so many times.
Post by defdes »
And finally, cover passes for good measure. The PO also messed up the locations of the front arm attachments which I corrected while I was at it, pushed the other one up to match.
RonM
Post by RonM »
Man, I would imagine that could have caused some interesting handling characteristics had you not caught it. :shock: The thought of that kind of shit keeps me up an night when I buy used stuff. Building my car has helped me develop some serious trust issues. Not sure yet if that's good or bad.
