Over 500 HP with a VG30, why go with a SR?
Re: Over 500 HP with a VG30, why go with a SR?
Maybe I'm wrong, but do not use the truck VG30, it had more torque. Thats what Jason at Canby said Spreadbury used in his 510. Spreadbury is using a SR turbo engine now. Correct me if i'm wrong. You will need the Z-31 engine.
About the frame rails, if the red wagon at Canby was putting out more than 600 ft lbs, that is the same torque that my Dodge cummins 1 ton truck puts down and the frame is boxed and huge! So is the tranny and rear end! So it would be a waste of $$ to go beyond the limits of what the car can realistically handle, body, drive train and driver judgment.
I had an L20 b in a two door and it was ton of fun driving that car, I just got caught up in the horsepower craze that clouded my judgement.
170 hp-180 tq
170 hp-180 tq
That's only if I don't get high compression pistons. And I could use the dohc head. can't do it the normal way now, you know me!datzenmike wrote:The KAZ22 would have a disappointing compression ratio I afraid.
I'm going to chime in here on the Awesomeness of Denis wagon. The first time I hear it i nearly pooped myself! It was that good!!! I was also competing in the slalom, and i hadn't run a slalom in.... many, many years, so I was a bit nervous. I was second driver, right behind Denis in his wagon. He left the line, blink, now he is about 14 miles away!! what just happened!! and the sound, that wonderful, cacophony of the fantastic internal combustion sextet! wow, WOW! If you haven't hear it in person, you can't really describe it. Come to think of it, even if you have heard it in person, it is hard to describe!
That car has some real six appeal
Tallis
If you are not sure, do research before posting something.chunstone wrote:Maybe I'm wrong, but do not use the truck VG30, it had more torque. Thats what Jason at Canby said Spreadbury used in his 510. Spreadbury is using a SR turbo engine now. Correct me if i'm wrong. You will need the Z-31 engine.
All VG30e's are useable. The truck VG's have camshafts designed around torque....the crankshafts are different at the snout between certain years and some other minor differences.
You can use whatever VG you want (3.0 or 3.3) as long as you use the accessories from the motor or figure out a way to adapt whatever you have. Change camshafts to early Z31 cams or whatever you desire it all works and can be made to work.
Denis Gagné
AKA VGwagon
69 510 VG30e swapped
73 240z VG30et swapped
AKA VGwagon
Well I just came across this and it makes me laugh. I really like the Rebello quote, only problem is that the basic thing about motors and power is that there is no replacement for displacement Even the late L Series guru Dave Weber of Malvern Racing would tell you that. VG adds very little weight overall and sits further back due to a bit less overall length. put the battery in the trunk and your pretty much good to go for any issues for the extra 150Lbs. You can easily get 250hp & equal amount of Torque, from a a 3.3 VG punched out to 3.5L with the SOHC Heads with some cams, and port work done to the intake manifold, using a 500cfm carb, You can have the whole motor good to go for max 3,000 (about the cost of used SR without all the extras you will need to both install and bump up the HP), and install is pretty simple unlike the SR and much easier to keep running not to mention cost of install and time . The 3.5 VG above is a stump puller and as anyone that races knows HP looks good on paper Torque wins races. As far as the 500hp, even spending the time to get that out of and SR and put into a 510 is just a ridiculus waste of time and money. A good performance car is all about balance and useable power and a well set up VG 510 is pretty damn good combo in n/a form that is pretty hard to beat. If you want the ultimate in power to weight then we should be talking about the Rover/Buick 215 swap. Total cost of about $9,000 will get you about 400+hp and tons of Torque, and the motor will be significantly lighter than the VG or SR or any L Series combo.
RonM wrote:Well VGwagon, You've made some strong accusations here, but maybe it would be better if we kept to the subject rather than making accusations based on nothing more than assumptions.vgwagon wrote:0
First off....the VG was never in production use, an aluminum block....I am surprised that someone with so much knowledge would give out such misinformation. The SR/VG/KA.....ect.....debate could go on forever.........who cares, every motor has its strengths and weaknesses. The VG will Handle a great deal of power on stock internals, Go over to Z31Performance and read for a while......see whats out there before just spewing BS. My VG30 with 400,000 km puts 191hp to the wheels, 208 ft/lbs of torque, headers and cam gears are the only real significant modifications, this on a stock ecu and stock tune. The torque gain is not useless. This HP to $ ratio for the VG in my estimation would be far more equal or better than the SR just based on displacement......Turbo charging a VG is no different that Turbocharging an SR, were talking 2.0 vs. 3.0, The VG's biggest weakness is port flow...To each there own.
You are right, the iron block VG was retired in 2004. Nissan introduced VQ aluminum block V-6 engine in 2000. Missing the Q was my mistake, not misinformation from David Rebello. I want to make this absolutely CLEAR, David Rebello is a class act all the way and he knows his shit. This conversation we had took place two years ago, and obviously the finer details escape me. David's suggestion was that the newer aluminum block is the only Nissan V6 motor light enough to have met my handling needs, and that this Aluminum motor does not hold up to the Big big. I hope this clears up any confusion.
Now, if we are going to enter a pissing match can I make one request? Lets keep to one subject of argument, otherwise we're fighting different battles; so to speak. In this thread topic the figure "500hp" was the standard for comparison of these two motors. Not 191hp. At 500hp however a 2000lb car is not going to gain anything from an additional 100 foot pounds of torque, but loosing the added weight off the front end it will. In order to get this kind of HP out of a VG we both know you'll spend significantly more money than an equivalent SR. Not only are performance parts more expensive for the VG, all the upgrade needs to be done on two banks of cylinders rether than one. Before accusing someone of "spewing BS" you'd better make sure you're on the same page, otherwise you're slandering someone needlessly.
Again, as I stated in my post there is the added variable of intended use, but if you have any opinions based simply on getting 500hp for their 510 and why someone might choose one or the other, I'm all ears.
The replacement for displacement is technology. Look at what manufacturers are doing with 2.0L turbo engines today. Or, most of the turbo variants that generally are replacing bigger/greater number of cylinder engines, but produce more power and get better fuel economy than the bigger engines. Even AMG is going this route in the near future.greatnorth510 wrote:only problem is that the basic thing about motors and power is that there is no replacement for displacement
If you're speaking specifically of engines commonly found in a 510, you need to state that.
Most of the rest of your post is subjective.
150lb in a 510 is not "very little weight" added. And so on.greatnorth510 wrote:VG adds very little weight overall...for the extra 150Lbs.
The decision to go with a NA V6 versus a I4 turbo in a 510 have much more to do with personal preferences (I like turbos, or I like NA throttle response).
If 150lb is "very little weight" to you, I'd love to know what "significantly lighter" means.greatnorth510 wrote:the Rover/Buick 215 swap. Total cost of about $9,000 will get you about 400+hp and tons of Torque, and the motor will be significantly lighter than the VG or SR or any L Series combo.
This is where your post lost credibility with me.greatnorth510 wrote:...HP looks good on paper Torque wins races.
-McWicked
I have another dimension to add to this argument...
Ask yourself, what is horsepower? How do you measure it? Where does it exist? What is its relationship to reality?
HP doesn't measurably exist. It is a calculated value that provides a normalized indication of average torque production per unit time.
On the other hand, torque is measurable.
there is very good engine theory on this webpage --> http://www.theoldone.com/archive/
That's a factory engine. 2.0L. One turbo. Factory-fresh driveability. It'll do that all day long for 100K miles before it needs plugs. That's your replacement for displacement.
SR20DET is better.
Why?
Because I have one!
No seriously, I have about 400whp and its completely useless in a 510. 500 would be even more useless.
Sometimes I feel like I should go back to a smaller T28 framed turbo, but I'm in it for the highway pulls!
Where the VG suffers with its heavy iron block it makes up with torque
RWD SR longblocks are harder to find and more expensive than the ubiquitious VG30E
BUT VG motors require new manifolds, new tunes, new wiring, oil pan clearance etc etc which bring the price back up on par with the SR20.
I chose the SR20DET for the only real legitimate reason, its in my personal comfort zone because my first car was a Nissan NX2000! I also wanted to reap the gas mileage benefits of having a lightweight car! I make 380-400whp and get 24mpg average.
Also, if I cant rev an engine to at least 7000, to me it's just boring!
Why?
Because I have one!
HP is a measure of work performed.510rob wrote:I have another dimension to add to this argument...
Let's have a look at an electric motor. It can produce its maximum TQ at zero RPM. But how much useful work can be performed at that speed? None. Torque is a static force that has no practical value unless allowed to act through a distance, at which point it becomes power. Power makes things go.
-McWicked
BTW- Thanks for the TOO link. I used to read that site all the time back in the day. Hadn't thought about it in years.
Seems to me that @ 500 hp the tires act as fuses to protect the drivetrain.
That's funny!datzenmike wrote:Seems to me that @ 500 hp the tires act as fuses to protect the drivetrain.
When we built my car, and it's subsequent upgrades, it was always kept in mind to just be at the edge of traction, with the available power.
Why...a car becomes kinda useless if you cannot use all that you have IMHO ( other than doing the all out top end blast). In my case as most of you know, it was Solo and hill climb use. If you had to back pedal on the throttle, you were NOT accelerating, which was a WASTE of time. Then, there is the safety factor of real world street and highway driving, on nice twisty roads. At mid to corner exit, it is FAST to be able to get full throttle, without the worry of the car suddenly breaking traction, and either having to get out of the throttle, or, call a tow truck to remove the car from the ditch.
Having a USABLE power band is where it is at, with a suspension that you can really use, and, tires that can at least handle most of that power transfer.
Years ago I went for a ride in a last gen Toyota Supra, dyno'd at 440 RWHP, blah, blah. The fellow gets on the throttle, we go I swear a block before this thing even starts to wake up, then, it fights for traction, even with the monster rear boots on the thing...the car was beyond useless other than the Mulsanne straight charge.
As Mike says, a "blown" fuse stops everything, and a 510 with 250 - 350 Hp is a way better choice for usable power, in both a safe and competitive aspect.
You people are starting to make me feel bad for having a VG in my car. I am starting to think like i should apologize for it:(
