CA18DET / 510
jaredperry
CA18DET / 510
Post by jaredperry » 12 Aug 2014 21:23
So I am coming to somewhat of a close to my CA18DET swap into my 510 and I am wondering what coolant hoses are typically used. I am using a KA radiator, the one that goes to about the insides of the headlights and has both the in / out on the passengers side.
Thanks,
PoorMtnKid
Re: CA18DET / 510
Post by PoorMtnKid » 13 Aug 2014 13:11
When it comes to radiator hoses just get a wire hanger and bend it to the path you want the hose to travel. Take the hanger down to the auto parts store and just ask if you can go to the back as it would be a custom application. This is what I did with my SR swap.
Re: CA18DET / 510
Post by okayfine » 13 Aug 2014 15:12
Not a lot of CA knowledge, it's not a common swap. Post a picture of what you're working with, it probably matches up with one of the other S-chassis engines (KA or SR).
jaredperry
Re: CA18DET / 510
Post by jaredperry » 29 Aug 2014 08:03
Both KA hoes worked. I just had to trim both hoses.
grimlid
Re: CA18DET / 510
Post by grimlid » 08 Mar 2017 23:35
This is an interesting motor swap, post a build thread.
Interested in the difficulty of the mounts ect. as well as ecu and electrics.
Decent horsepower and decent price point from JDM.
Didn't your Mom ever tell you, " nobody likes an a__hole?"
