SR20DET throttel cable
onekickkawi
Post by onekickkawi » 10 Jun 2015 11:12
I have read that most people use the 240 throttle cable. I ordered one and installed it but it is really short. it works fine for testing right now but I would like to find something longer. Any ideas? I believe the one I have is about 32" See Picture.
PoorMtnKid
Re: SR20DET throttel cable
Post by PoorMtnKid » 10 Jun 2015 11:43
That is what I used, I have not had any issues with mine thus far with multiple track days on it.
onekickkawi
Post by onekickkawi » 10 Jun 2015 15:18
I would just like to route it behind the engine block for a cleaner look and so its not so tight. The car is still being pieced together but I would like to find a good cable. I know there are universal ones so I may have to go with that.
PoorMtnKid
Post by PoorMtnKid » 10 Jun 2015 16:41
I get what you mean. If you find a solution update this thread so I can follow up.
onekickkawi
Post by onekickkawi » 10 Jun 2015 21:10
will do! finally making good progress on the car
dislexicdime
Post by dislexicdime » 11 Jun 2015 06:52
I used a locar cable and cut it to fit
onekickkawi
Post by onekickkawi » 11 Jun 2015 09:12
Really getting momentum on the 510 again. been long over due. trying to get everything cleaned up... and then bodywork one day. I am running all connections through the firewall using some old military banjo connectors. makes a nice, clean, waterproof fit. I can disconnect and reconnect if needed and there is only one way to connect it so no worries about a short or mistake.
onekickkawi
Post by onekickkawi » 17 Jul 2015 14:00
Hey All so I ended up buying a throttle cable for an eclipse. I Really like the clean look of it (makes a nice 90* turn after the firewall). I had to cut off 12"~ off the end. I then took a 3/8-24 x 2" bolt and cut the head off. I bored a .25" hole 1.75" deep and a 1/8 hole through the rest.
Post by JordanTr » 18 Jul 2015 08:28
Probably too late now but the S13 KA24E throttle cable is a bunch shorter than the S13 KA24DE cable.
Nice job on the custom cable!
onekickkawi
Post by onekickkawi » 20 Jul 2015 13:08
I only tried a sr20 one and didn't like its fit... my overall goal is to keep the car as clean as possible and this seemed to do the trick
PoorMtnKid
Post by PoorMtnKid » 20 Jul 2015 15:47
Nice work. Any pics with it installed? What year eclipse?
onekickkawi
Post by onekickkawi » 20 Jul 2015 15:57
I measured it up, I just havent installed it (when I have free time its too hot... aka lazy me)
The cable was from ATP part number Y1154. Should fit Eclipse's from 1990-1995
The cable will be way to long if you dont trim it down though
